No blue lights - just stopped working
Started by Dean, September 16, 2010, 05:59:56 AM
GreekSpy2001
Dean
Interesting thread.  Have a problem of PC restarting every 36 hours when running Radarbox SW on Win 7 64bit.
Now you are on Win 7 64bit do you run your radsarbox 24/7 or only when required.  If you are 24/7 does your machine OK without any resource issues and utlimatly unsceduled restarts?
graham
Dean
It's working fine. Couple of things that seem slightly odd. It always starts up centered on EGLL and with the altitude display on which it didn't used to to, no really bothered by that tho'.
I only run when I am sat here so no experience of a reset (yet anyhow). I may leave it on next weekend to build up my antenna polar etc.  |Let you know if it starts being naughty.
GreekSpy2001
THanks Dean.  Would be interested to hear your findings.  In my case between 36 and 48 hours my memory commit charge reaches 100%.  At this point my PC complains of lack of resources and recommends I close programs.  Eventually it gives up and resets.  Only had this when i moved upto Win7 64bit, and only happens if I run the Radarbox sw continuously.
Be good to know if its my install or it effects others.
Graham
Dean
Been on for 2 days - no memory problems.
GreekSpy2001
ok thanks..  Seems like my install...  Bother
GRaham
GreekSpy2001
Dean
Quick question.  Ur install is just basic Win7 64bit or have you done any windows updates?
Graham
