Database Validation Query ?
Started by Smudger98, October 25, 2010, 01:04:53 PM
Northern Watch
Hi Chris,
Please can you explain how you are deleting the photos, is it by going in to programme files until you get to Data/photos or can they be accessed through some other way.
Keith
If it's any help Keith, I simply moved the existing folder to a different location and the let the things take their course.
Didn't take long for a new folder to self-start and get up to speed.  Having satisfied myself all was working well, I have now deleted the old folder.
Keith
Another way of getting to the photos folder is to open MyLog, click on the All Photos tab at the top, then click the Explore Photo Folder button.
HTH
ACW367
Quote from: Northern Watch on October 27, 2010, 11:24:45 AM
Hi Chris,
Keith
Yes it is a deletion of the thumbnail picture in the data/photo folder which is a JPG file named by aircraft registration.  This will cause your system to re-search Airliners.Net for a replacement photo (which may well be exactly the same as the one you just deleted).  At the same time this also forces your system to interrogate the updaters database, resulting in the information for this aircraft changing with the data we have updated.  Us updaters recommend currently you are selective with the photos you delete, because you will also get the corruption to the ICAO code, which has been well documented and which Airnav are investigating.
Northern Watch
Bratters, Rod, ACW367,
Thanks guys for the speedy response. I have done a lot of updating myself and until the ICAO code problem is resolved I will be selective on what photos I delete.
Once again thanks for the valuable information.
Keith
ACW367
Some fleets that have undergone major changes and standardisation and which we recommend refreshing to get up to date information.
All aircraft for bmi, Continental Airlines, Northwest Airlines FedEx Express and all their regional partners.  Also any regional aircraft with JAL, ANA feeder companies and any that currently show as Delta Airlines instead of Delta Air Lines.
Northern Watch
ACW367
When you say "refreshing to get up to date information" what is the best way of doing this?
Keith
ACW367
Quote from: Northern Watch on October 27, 2010, 12:42:37 PM
ACW367
Keith
By deleting any photos from the file as and then clicking on airframes from those companies as you see them on the network or myflights.  There is no way to bulk trigger the transfer of new data, it can only be done as aircraft appear on your box.
ACW367
flybhx
OK I'm officially confused. If I click on an empty space for a new mode s code it doesn't appear in the table. I don't use photos at all. How come the frame isn't populating?
Quote from: phil zech on October 26, 2010, 12:07:40 PM
I have Real Time Network access, so when a new aircraft appears with just Mode S code , I click on empty space ,  and aircraft details and photo appears.
Phil
Chris11
Hi Chris,
Keith
Apologies for late reply but I was out of town. I have Win 7. Windows explorer has a handy little search window in the top left so I keep Windows explorer open in the data/photo directory. When I want a refresh I right click the registration and select "Copy selected field into clipboard". I then go to explorer and paste into the search window which brings up the pictures that need to be deleted.
ACW367
Quote from: flybhx on October 27, 2010, 11:34:58 PM
Phil
Sorry FlyBHX
Not sure how the system works when you don't request photos.
Airnav Support - Any suggestions???
I shouldnt imagine that having photgraphs or not would make any difference otherwise new aircraft on delivery where no photograph exists wouldnt populate.
If the data exists on the server for the aircraft in question it should popoulate where no data is held by the user.  If some data is held on the users database no update is done to avoid over writting of the data held and a manual update is required.
If an aircraft shows with hex only and doesnt populate, the data isnt in the server and an update is required.
If you don't have photos on, it won't check the online database if the Mode-S Hex code is in the local database.
Northern Watch
Chris11, ACW367
Thanks for you replies, sorry I could not get back straight away. I have tried deleting a small quantity of photos and will try and re-populate once my grandaughter lets me have some free time.
Rgds
Keith
BadWolf
Just as an aside, I have found that Firefox's SQLite manager add-on is a handy tool to update entried in my local db. It allows editing of all the entries in an aircraft listing before updating.
