Started by orkney, November 10, 2010, 06:44:10 PM
780353 not known at this time.
Chris11
Quote
Appeared early this morning as EU2739. So we now have 780353 and 780355.
Consensus of opinion  suggests they are the two ex Air Berlin A320-214s c/ns
2696 and 2835 with registrations B-6728 and B-6730 respectively. Which is which?
Once we know we will put them in the d/b
chewycanes
Me again. After the last post when i had a corrupted reg i am a bit worried about these two.
Can you check that the following two are in the database correctly and that i again have some kind of corruption.
3B77FC should be F-RADB A310 ser no 422 French airforce from Gatwick Aviation. (My explorer says is a English Electric Lightining Kuwait airforce).
3B77E7 should be F-RBFA A319 Ser no 1485 French Airforce from Gatwick Aviation. (My explorer saya its a Chung Kuo Taiwan airforce).
Brian
Hi Brian,
They are in the database correctly.
However you will have the version of the database which came with the system which is incorrect and may well be giving you the incorrect info.  I cannot check against my own database as I changed these two a long time ago for the very same reason.
Aa manual update wil be required until the next software version is released.
chewycanes
Hi Alan
Thanks for checking anyway.
Brian
Hawkeye
Hi team,
N851NW logged this morning, and N852NW, are still showing as Northwest in my database, (and photos), instead of Delta.
Syd
Syd, you will require to update manually until a new Navdata is available.  The d/b has been updated but I will have a look and see if there are any new photographs avalable on Airliners for these 2 aircraft.
Syd,
Thats me put new photographs on for those 2 aircraft.  Yoy will require to delete the photographs held on your personal computer in the program files/Airnav systems/Radarbox/Dat/Photo/ file, or whereever the photos are held.  You will also require to delete the info in the pt. lk, pt2 and lk2 for these aircraft in database explorer.  That will force the new pics to be uploaded next time you see those aircraft.
Hawkeye
Thanks for the info.
I've done the necessary regarding photos, but having cocked things up when trying a manual update previously, I'll keep away from that and hope that Airnav issue an updated Navdata file sometime.
Any comments on if or when that might happen Airnav?
Syd
54901 - Jim
Here's one from today's log -->
A4EFDB / N417TS / DA42 / Diamond DA42 / Corporate Aviation Advisors Inc / 42.AC017
Thanks!
KOSH - Oshkosh, Wisconsin USA
orkney
Hello
N417TS is now added - thank you.
Andrew
Chris11
4CA8ED  EI-IME Airbus319 c/n 1740
4CA8ED confirmed as EI-IMD,
4CA8DE confirmed as EI-EME
4CA8DF confirmed as EI-EMF
All Alitalia re-registrations are in the database, these appear to be getting carried out at Heathrow while aircraft are night-stopping
Chris11
ACE62A N930FD B757-2YO c/n   25240  FedEx Express
