Started by orkney, November 10, 2010, 06:44:10 PM
Niklas, UR-DPB is 508228.  If its that aircraft its miscoding.
superspotter
Hi Guys;
I have an interesting one here in HKG area for that last two days but not seen in HKG; 38037A. According to my Db it is not allocated but it comes up in the aircraft list grid as F-WWKS which is an Airbus test reg, in the aircraft type it just says "Air"??
superspotter
Regarding my last post, just seen the airline logo appear as HNA Hainan Airlines so could this be one of Virgins newly leased A330's??
superspotter
Further to my last post!! This aircraft has just landed at HKG as CBJ535 and it was a Gulfstream G200! Looked on Libholeradar and this hexcode has been seen as B-8083 so I can confirm this. regards clive.
chewycanes
Morning Alan
4CA63E EI-ECF RV6 John Bailey (from GA)
3C4594 D-AALT (From GA) previous callsign OLT180 Ostfriesische Lufttransport (from LIBHOMERADAR)
other than that no data.
Brian
Superspotter,
38037A is in the d/b and is as you state an Airbus test registration for A330 airframes.  It's AT is ZZZZ as it could be any A330 model.
Re B-8083, its hex is 78037A, ICAO GALX and as it is c/n 037 it is an Israel IAI-1126 Galaxy.  Aircraft after c/n 056 are Gulfstream Aerospace G200.  It is operated by Capital Airlines and has been added to the d/b
flygfantast
Quote from: Runway 31 on April 07, 2011, 09:45:11 PM
Ok, then it could be UR-DNX.
According to the info I have UR-DPB, UR-DNX, UR-DNW and G-BWIR is currently operating for Skyways.
Niklas
Cable: Ecoflex-10 (10m+1m)
Morning Brian,
4CA63E is G-RVNI miscoding with its former hex.  It should be using 406354.
I dont have anything on 3C4594 D-AALT, probably another OLT miscode but I dont know which aircraft.  If there is anyone out there with info let us know. 3C7D49 D-AOLT was miscoding previously so it is possible it is it in another guise.
Niklas,
UR-DNW is 508220
UR-DNX is 508221
flygfantast
From mode-s forum
514053 = 4L-SKD, IL76, Ilyushin Il-76TD, c/n 1023410344 / 8406, Sky Georgia
Niklas
flygfantast
Quote from: Runway 31 on April 08, 2011, 07:47:02 AM
Niklas,
UR-DNW is 508220
UR-DNX is 508221
Ok, I'll see can find out anything more... Atleast it should be a E145...
Niklas
flygfantast
Not populating, todays log:
4AD965, SE-VKE, Atec 122 ZEPHYR, c/n Z1580608A
47833E, LN-RDT, DH8D, Bombardier DHC-8-402, c/n 4038, USK Trevally Co. Ltd
(11.03.11 LN-RDT- Application for acceptance of maintenance procedures to return parked Bombardier Dash 8 series 400 aircraft MSN)
4B1797, SE-LTV, SB20, Saab 2000, c/n 2000-063, Golden Air, using miscode of old HB-IYH
Niklas
mikek
not populating:
C87F01, NZ7572, B752, Boeing 757-2K2, New Zealand - Air Force, 26634.
This was previously using code C8251D, but has now changed to it's correct code. The old one can probably now be removed too.
The only remaining RNZAF aircraft yet to be seen with it's correct code is NZ7004 (C-130H).
Mike
