Started by orkney, November 10, 2010, 06:44:10 PM
Morning, by "feeding" the ICAO Identifier not or false filled bug I found this two wrong entries:
E485BD PR-NOA L10 Let L-410UVP-E Turbolet ... It shall be L410 instead of L10
49D070 OK-LRA L10 Let L-410UVP-E Turbolet ... Same as above.
Morning Ingo,
Both those aircraft are in the database as AI L410 already and I also checked my database explorer and they are also correct there as well.
The only aircraft with an AI of L10 in the database is CF-TCC Lockheed L-10A Electra
Bob SEN
Hi guys........ just popped up is 424166 showing VP-C0D s/be COD
cheers
Bob
1/2 a mile South of EGMC/SEN
chewycanes
Morning Alan
49D241 OK-RHM BE40 ? (from modes forum)
3E3F1F D-IPCH (from GA no other data)
Brian
Morning Brian,
OK-RHM Beechjet 400 c/n RJ-56, ex N70DE
3E3F1F D-IPCH routed Keflavik-Prestwick-Hamburg yesterday afternoon and is thought to be a C25A
anorak
399620 / FHFRA no pop and nothing on Airframes
Dave.
Dave. Exmoor, North Devon.
Dave,
I noted it as it came over me on its route from Reykjavik-Bordeaux.  I asked on the mode-s forum and was advised that its flightplan shows it to be F-HFRA, Cessna 501 Citation I/SP.
Reagrds
flygfantast
4AB4AC = SE-MEL, DV20, Diamond DA20-C1 Katana, c/n C0560, Private owner
Niklas
Cable: Ecoflex-10 (10m+1m)
Chris11
70C0B2 Flight ID - A4OCX
Not populating
I saw it myself over Brazil Chris and will add it to the d/b when details become available.
chewycanes
Afternoon Alan
7C921B VH-ZZH BD700 AV WestAircraft Trust (reg from libhomeradar and the a/c from search of VH-ZZH).
Brian
#2383
Thanks again Brian.  VH-ZZH is using a miscoded box as its correct hex is 7C821B
Chris,
70C0B2 courtesy John Hargreaves A40-CX, Embraer 170-200LR-175LR, c/n 17000325, Royal Oman Police Air Wing
