Started by orkney, November 10, 2010, 06:44:10 PM
Tarbat, if you have the wrong details delete them and re-populate,  If the details auto-populated are wrong tell us and we will amend them.
Davidp124 I actually have 85-1262 as a Beech C-12F Huron and from my investigations on the internet so do others so amended to read as such.  It is operated by the US - Army Tennessee National Guard
Picture and details on www.airport-data.com
Construction number given as BP-053.
Google in 85-1262 for all the information.
davidp124
Quote from: Runway 31 on December 02, 2010, 03:41:24 PM
Ok, Thanks for the update.  I was going by the Scramble d-base and a local TN area monitor.
#244
No problems David, keep on sending them in.
ACW367
Alliance names have now been removed from all DB records.  Most of you will have these designations in your Navdata from before our team formed when the info was pulled from ANet.  If you now wish to change them, delete the relevant picture on your C: drive and it will repopulate the next time you pick the aircraft up.
ACW367
Many thanks, ACW and all the Updaters.
chewycanes
AE2FF4 callsign S2769 out over dover this morning.
Have been informed it is
82-8000 VC25A USMil
Brian
54901 - Jim
Here's one from this morning's log -->
A811C5 / N619SH / BE9L / Hawker Beechcraft C90A King Air / Elliott Aviation Aircraft Sales Inc / LJ-1737
Thanks!
KOSH - Oshkosh, Wisconsin USA
Hi Brian, yes this is Air Force 1 using a Tac Code.  It normally uses its "legal code" of ADFDF8.  Info from the mode-s forum.
chewycanes
Cheers Alan.
I actually got to see it.
Brian
ACW367
Quote from: chewycanes on December 03, 2010, 10:47:57 AM
82-8000 VC25A USMil
Brian
They have done this a few times recently, usually when POTUS has looked to undertake surprise visits to operational theatres.  I believe that on occasions when outbound from the US they have even falsified the flightplan saying the aircraft is a C-37 Gulfstream or C-32 757 to increase security.
chewycanes
Another couple
43E879 IOM ?
4241AF VP-CVW A319 ?
Brian
Brian
43E879 = M-DADI, F900EX c/n 313 delivered/first noted this morning.
4241AF=VP-CVW, A319-15CX c/n 4024 Volswagen already in d/b
