Started by orkney, November 10, 2010, 06:44:10 PM
Thanks Neroon was only advising what we had it in as.  I take it Bundesministerium des Inneren mean Ministry of the Interior.
Quote from: Runway 31 on January 06, 2011, 06:03:05 PM
Well, it was the same I had in my Database until I got suspicious because of the CHX4 flight id, so I started a small investigation which ended with the cross-check posting...
Another not populated from today:
4CA241 EI-SMF Fokker F-27-500 Friendship   Air Contractors 10633
#573
Thanks Neroon79.
EI-SMF became 5Y registered and was last noted engineless last year in Nairobi.
Chris11
springbok
VENUS  is the callsign of    89th AW, Andrews AFB, MD (SAM acft w/o VIP)
a bit of a search on the web and the general consensus is that this is a B757 (C32) 09-0015 but no other info on that to be found ...
I have the same info, or lack of info  for VENUS95.  It seems to be one of theose aircraft that is often noted but nobody knows what it is.  I think the VIP link may be the reason.
Dana
Anyone knows the airplane registration with this two mode s code: 508220 and 508221 ? I know that the both airplane are E145 and the owner is Dniproavia Ukraine...
Also the ex- I-EXMA became recently UR-DPB with CN 145250 and the new owner is Dniproavia as well.
Dana
508220 = UR-DNW E145 c/n 145286 Dniproavia
508221 = UR-DNX  E145 c/n 145316 Dniproavia
Both in d/b
Dana
chewycanes
Currently got the following not populating.
ADDE74 ?
Brian
Bob SEN
Morning Alan
70C0AE n/p.. flight id E5050039
cheers
Bob
1/2 a mile South of EGMC/SEN
Brian, comes out as N993GX but nothing assigned to that by FAA.
Horsham Spotter
Good morning Alan.
Just seen this one 853047 using callsign XACHR
Done the normal look ups and Yahoo Modes group comes up with this.
853047/JA39QZ/Gulfstream Aerospace GV-SP G550/5182    ex XA-CHR
Hope of use.
Steve.
3.1nm miles south of EGKK westerly App & Dep.
Morning Bob, Its been noted flying in the Sao Paulo area, Embraer test flying before delivery.  Hopefully see it around here on delivery to Oman soon.
