Started by orkney, November 10, 2010, 06:44:10 PM
ACW367
Chris, A50077 and 758140 (RP-C8391 for AirPhil Express delivered yesterday evening) were both on the DB.  I to had problems getting full details for N421MP when it appeared on the network, so I deleted and re-inserted the record on the DB to see if that sorts it out.
461B08 is a Finnair A333 OO-LTO with one bad transponder box.  It also uses its real code of 461F08.
Regards ACW367
Hawkeye
Hi  team,
One from today's MyLog:-
40612A is G-BRXT,  BAE 146-200  Bae Systems(Operations) Ltd
regards
Syd
Chris11
 4CA8EF EI-IMG Airbus A-319-112 c/n2086 Alitalia
Chris11
0D05DB not populating - Volaris
Syd, I put G-BRXT in last night as it came over me.  Its ex-OY-RCW
Chris EI-IMG and XA-VOR A319-132 c/n 2296 of Volaris now in.
Many thanks
Chris11
3CE2D2 - Flight ID - D-CNEW - that checks but unable to find information on the aircraft
chewycanes
Can you check the following two for me. Apologies if they are already done.
A309DD N295UP MD11 UPS
AB7E33 N84HD GULFSTREAM IV TIME WARNER CABLE INC
Brian
Chris saw tha tone myself and like you I cannot find anything on it.
Brian, both already in and no need to apologise, please keep sending them in.
Chris11
4BD143 TC-TJC Company is  Corendon Airlines not Sun Air
AABBF8 N791CK B747-251F(SCD) 23888  Kalita Air
Cheers Chris added and amended.  N791CK had been storage.
Chris11
A320C9 N330R is ex PT-PVS, a Embraer EMB-505 Phenom 300 c/n50500031
Quote from: Runway 31 on November 16, 2010, 04:02:36 PM
Chris, a check with the FAA website actually shows that N300R is a reserved registration since 19/07/2010and it is not allocated at this time
The Beechjet you refer to has been re-registered N330R and the B350 became N270AB.
If you see it, it must be one of the previous users still showing its old hex, probably the Beechjet as it was re-registered in June this year
N300R certified 17/11/2010, the day after the statement above, now in d/b
Chris11
Yep - saw that Alan.  FAA needs to get their database up to date :) :)
You guys are doing a fantastic job. There are very few aircraft that are not populating these days. In fact the vast majority appearing here are re-registrations or new deliveries.
Thanks for a great job
flygfantast
4AB308 SE-LXH SB20 2000-007 Golden Air
//Niklas
Cable: Ecoflex-10 (10m+1m)
Many thanks Niklas, SE-LXH now added.
