Started by orkney, November 10, 2010, 06:44:10 PM
orkney
Hello
We didn't have that one in yet but it is in now.
Thank you once again.
Andrew
mikek
Not populating:
C81DE4, ZK-ZNB, GYRO??, Carpenterie Pagotto Brako Gyro, Christel Diemer and Michel Babou, 65005.
Mike
orkney
Hello
I have now added C81DE4.
Thank you.
Andrew
Hi, some not populating AC from yesterday:
222ADE (from not allocated address range) nothing more
3C6611 Germany / nothing more
3D43D6 D-EXYC DV20 Diamond DA-20C-1 Katana Segelflugschule Oerlinghausen CN:?
3E7116 D-KIAG SF25 Scheibe SF-25C Falke 2000 Verein für Segelflug "Wittekind" Enger e.V. 44442
3ECF01 D-KTIV SF25 Scheibe SF-25C Rotax Falke LSV Vlotho 44614
3FEC09 D-MIEM FDCT Flight Design CT SW Private CN:?
3FEDE3 D-MKTI nothing more
3FEFF4 Germany / nothing more
47807F Norway / nothing more
4C8016 Cyprus / nothing more
869142 Japan / nothing more
First Batch
second batch:
4A934A Sweden / nothing more
3ECBAA D-KSBY S10S  Stemme S-10VT 11-101
A0DD29 N155EC C525 Cessna 525 CitationJet AIRCRAFT GUARANTY CORP TRUSTEE   525-0024
45B165 Denmark / nothing more
3D202E D-EKLA WA50 Wassmer    WA-51A Pacific Rainer Grieger 96
That's all for now.
chewycanes
Good morning.
AE2736 KC-3802 C130J Indian Airforce (left prestwick this morning out over south coast)
Brian
flygfantast
4A934A decodes into SE-DZJ, not in Swedish CAA. Possible miscode or new aircraft.
Niklas
Cable: Ecoflex-10 (10m+1m)
orkney
Hello Ingo, Niklas and Brian
The database currently isn't working but I will do your requests when it comes back on line.
Thank you
Andrew
orkney
Hello
All ones that I could find are now added.
Thank you.
Andrew
Dana
Someone knows details about this mode s :
4A361A ?
3858DB ?
4895EB ?
Thank you :)
orkney
Hello
Sorry, I can't find any of them anywhere.
Thank you.
Andrew
chewycanes
Good evening
The following are not populating.
405EFD G-DOTY RV7 Humphrey A D
A7C599  N60HD H25B Pelican dev
Brian
orkney
Hello
G-DOTY is now added but the FAA has no record of any aircraft currently using N60HD .
Thank you
Andrew
flygfantast
4AB4A4 = SE-MED, DA20-C1, c/n C0562
Niklas
flygfantast
4A361A = YR-MPZ no more info
4895EB = SP-FPL, C206, Cessna 206H Stationair
Niklas
