Database Update Requests
Started by orkney, November 10, 2010, 06:44:10 PM
chewycanes
Morning Alan
Hope to clean up on this one (but i doubt it)
4CA1F6 EI-DAZ B737 Ryanair (detected by Libhomeradar 7/2/11)
4004E9 no data so maybe a corruption but cannot see anything close to it.
Brian
Morning Brian,
Have some faith !
4CA1F6 was EI-DAZ with Ryanair but is now VQ-BKR with NordStar having been delivered to them last month
4004E9 was G-DOCK in its previous life with BA.  It is now ZS-OTH with Comair in South Africa since 2004.
chewycanes
49128C Callsign CSDTL LJ45 ?
Brian
Brian,
49128C CS-DTL Learjet 45 c/n 45-280
neroon79
Evening, first batch (before dinner) from Sundays LOG
343611 (Spain)
3CE731 D-COWB C25B Cessna 525B Citation CJ3 Private 525B-0220
3D04BF D-EAAX M20P Mooney M-20R Private
3D066A D-EARI (Tracked again this combination, Don't know whether it is still the BE35 or not)
3D089A D-EBMW C207 Cessna 207 Super Skywagon Private 20700088 (First time ever I tracked this type)
3D0B02 D-ECKO AA5    American AA-5 Private
3D1589 Was D-EGKF, now it is ?
3D1660 D-EGSM P28A Piper    PA-28-181 Archer 3 Private
3D18BB D-EHPR P32R Piper Aircraft Inc PA-32R-301T Saratoga 2 Private
3D19FA D-EIBY HR10    Robin HR-100/200B Royal Private 126
3D1DF3 D-EJPB
3D2B7C D-EOSI WA40 Wassmer WA-40 Super 4 Private (sometimes miscoded with 3D2B00)
3D3704 D-ETBW PULS Pulsar Pulsar Pivate
3D3A88 (Germany)
3D3FF5 D-EWLH (Still not Populating)
3E5FC4 D-KBLS DIMO    Diamond Aircraft Industries HK-36TTC Super Dimona Private 36553
3E7289 D-KION SF25    Scheibe SF-25C Rotax Falke Private 44526
3F84A6 (Using GAFMED Flight ID, so this might be one of the MEDEVAC A310 of the German air force)
3FAC22 12+06 CL60 Canadair (Bombardier) CL-600-2A12 Challenger 601 German Air Force 3056
End of batch No. 1, No.2 will be delivered later...
11.75nm ESE of EDDV
HW:
Cable: 25m of ECOFLEX 15+
NB: Asus P53E 24/7 op.
PC: 28"4K + 24" Monitor
AirSpy mini @RPi3
neroon79
Second Batch:
3FE9FD D-MPAN ECHO Tecnam P-92 echo LSG Bad Pyrmont
3FEA2B D-MIIS Zenair (Exact Type: ?) Private
3FEA8C D-MMBD IMPU Impulse 100 Private
3FEAF1 D-MWMP
3FEB08 D-MCCT FDCT Flight Design CTsw Private
3FEBD8 D-MOOJ BREZ Aerostyle Breezer Private
3FEC8B D-MRKN ECHO (Still not populating)
3FECFB D-MVHM MRC1 Dyn'Aero MCR-01 Private 109
3FED82 D-MREI in 2007: Platzer Kiebitz B2 Now:?
3FEDDD D-MDYG WT9 Dynamic WT 9 Private
3FEE37 D-MFIT BREZ Aerostyle Breezer Private
3FEF97 D-MRGW FDCT Flight Design CT SupraLight Private
3FEF9D (Germany)
3FEFB3 D-MVWH GYRO (Still not populating)
3FEFF8 D-MKCC (nothing mew...)
4405A2 OE-KYH was a TRIN in 2004, now?
48BA40 SP-OTA PA34 Piper PA-34-220T Seneca V Private
508097 (Ukraine)
That's all for now!
11.75nm ESE of EDDV
HW:
AirSpy mini @RPi3
Hi Ingo,
343611 unknown
3D04BF, Ihave this D-EAAX as cancelled to Morocco and I note that Airframes has the hex with the registration CN-TRK as noted 9/1/2011
3CE731 comes out as D-COVX unknown D-COWB is 3CE735
3D1589 I have as D-EGKF SOCATA TB10 Tobago c/n 166
3D18BB is a Piper PA-32R-301T Turbo Saratoga SP
3D1DF3 D-EPJB, Piper PA-28-235 Charger, 28-7310007
3D2B7C D-EOSI, WA40 is now HA-VEV
3D3704 c/n 413
3D3A88 unknown
3D3FF5 unknown other than registration
3FAC22 and 3F8A46 are tactical codes
Thanks again
neroon79
Quote3D04BF, Ihave this D-EAAX as cancelled to Morocco and I note that Airframes has the hex with the registration CN-TRK as noted 9/1/2011
Well, this is consistent/plausible, because I tracked it with CNTRK Flight ID.
As for 3CE731 (with DCOWB flight ID): Noted as recurring miscode of 3CE735
thanks for the feedback.
11.75nm ESE of EDDV
HW:
AirSpy mini @RPi3
Hi again Ingo
3FEA2B nothing know other than registration
3FEA8C D-MMBD nothing known other than registration
3FEAF1 D-MWMP  Flight Desing CTSW c/n unknown
3FEB08 comes out as D-MEPY.  Airframes has got D-MEPY and D-MCCT against this hex with no other details available.
3FEBD8 D-MOOJ nothing known with me, Airframes, GAS or Libhomeradar
3FEC8B D-MRKN, Tecnam P-92 Echo 100S c/n 507
3FED82 D-MREI nothing known
3FEF9D unknown
3FEFB3 unknown
3FEFF8 unknown
4405A2 OE-KYH SOCATA TB21 Trinidad TC c/n 555
48BA40 SP-OTA Piper PA-34-220T Seneca V, c/n 3449325, SG Equipment Polska
508097 unknown
Thanks again
chewycanes
484B49 PH-KXX F50 Mass Holding N V
Brian
Brian,
Its on delivery to Indonesia for Sky Aviation.
neroon79
First Batch of Monday LOG:
For Info: D-ELFU with 222222 Hex.
342652 (Spain) / Airframes: known Miscode of 020 a CASA C-295 M
3C4989 (Germany)
3C667D (Germany)
3CE6D7 D-COST / miscode correct address: 3CE6DF
3D21B9 (Germany)
End of first batch. Rest today evening.
11.75nm ESE of EDDV
HW:
AirSpy mini @RPi3
Hi Ingo,
3C4989 comes out as D-ABLI, last one I have with tha tregistration was a 727 whih was B/U
3C677D unknown
3D21B9 comes out as DE-ELAF, the last aircraft I have with that registration is marked as written off
EK01
Hex code 343611 appears regularly over here in Spain but never ties up. I can only assume that it is used for test flights.
chewycanes
Can you check the two Morrocan Texans as the reg for the second i think is wrong
0200B8 CN-ATI
0200BD 14  CN-ATL ?
Brian
