In My Flights but not plotting on map
Started by GreekSpy2001, January 18, 2011, 10:58:01 AM
After exchanging emails with customers we have some details to what may be a common factor.
To those who are seeing this can you please confirm you have the following, either my posting here or emailing us:
- Software 4.03 and have paid for the 3D version
- Problem on 2D Map
- Occurs with either network on or off
Thanks,
skidmarks
THOUGHT THIS WAS A PROBLEM BUT IGNORED IT. CAN SOLVE IT BY ZOOMING IN AND OUT ON MAPS.  HAPPENS AWHILE AFTER STARTING AIRNAV IN 2D MODE MAYBE 3-6 HOURS RUNNING - I VERY, VERY SELDOM USE 3D.
VISTA 64BIT - ON ASUS G5050V LAPTOP. 4GB MEMORY.
YES - PAID FOR 3D 4.03.
USE NETWORK 95% OF TIME SO DON'T KNOW ABOUT NON-USING NETWORK.
REGARDS - SKIDMARKS
airdata
I am using v 3.13 on windows 7 home premium 64-bit.  I do not subscribe to network (so the network is off), I also do not have 3D.
Again, this is comes up from time to time and everything can run perfectly for days on end and then all of sudden this problem appears and is only rectified by clicking the "process hardware flights" and clicking it again.
Quote from: AirNav Support on January 20, 2011, 08:39:41 AM
airdata,
What version of the software do you use? and are you using 64bit?
Under the flight path, 5NM from runway 23L threshold at Auckland (NZAA), New Zealand.
GreekSpy2001
have 4.03 running in 2d mode  have not subscribed to either 3d or network mode  running win 7 64 bit
hth
graham
GreekSpy2001
for info. Came to my machine at 2200 this evening.  Only 20 flights in myflights with the world symbol.  Only 1 plottig on map.  Toggled Process Hardware and they all appeared.
Graham
GreekSpy2001
10 mins later same problem....  Seems to be getting worse.
Graham
Vector
I have version 3.13 running on Windows 7 64 bit, I do not use the network for Radarbox or PP.
I am seeing ADS-B aircraft tracking locally in PlanePlotter which is fed by the Radarbox, they are not showing as tracked by the Radarbox software no ADS-B indicator and not on the Radarbox map. I have the internet connection turned off so the PP data must be coming direct from Radarbox and the aircraft are not spurious signals because they are on the VHF radio under ATC control.
Vector
I have done further testing today and been in the location of BHX and EGNX some aircraft on the ground are plotting as they taxi in PP which is fed by the Radarbox. In the Radarbox list they are displayed as none ADS-B (No Globe) when the aircraft get airborne they have the globe and start displaying.
Very strange?
Marpleman
I get this all the time - initially without a globe and not tracking, and then after about a minute, the tracking kicks in
Emirates appear to be more affected with me for some bizarre reason??
Vector
The aircraft I saw tracking on PlanePlotter and not Radarbox where Ryanair, DHL and UPS.
The Radarbox is receiving them but not the software for some reason.
#55
Just one thing to note when comparing Radarbox and Planeplotter screens.  Make sure the timeout settings on both are identical.  In Planeplotter "Omit Aircraft After" = The sum of the two MyFlight timeout settings in Radarbox.
For example, I use:
PP Omit Aircraft After = 3 minutes
ANRB Mark as Timeout = 17 seconds
ANRB Hide Timeout = 163 seconds
Also turn of position prediction in Planeplotter.  I'm not saying this is the cause of these problems, just one thing to eliminate from the factors that can affect any comparison between ANRB and PP.
Vector
In my case the timings of PP are the sum of the two.
It does not appear to be a timeout issue because the aircraft were just starting up to taxi, they appeared on PP as they were taxiing but not in the Radarbox software until they were up in the air.
For example an aircraft has just called up to taxi at EGNX and it is plotting on PP but in the Radarbox software it is displayed as non ads-b. I am sure it will appear in a few minutes.
harvey
I also had that Problem for a long time and tried a lot.
The only thing what brought a big improvement, was when i deleted all my history data  O-:
Before that, the only what helped for the short moment was to open a new 2d map on map menu.
In my case:
- there was no significant change if i used network or not.
- the plans  missing on 2 D were definitely in range (after takeoff on nearby cologne airport.)
- the flights completely appeared in the interface immediatedly after takeoff, also in the 3D map, but only after long time in 2D.
- it dident matter if it were high or low traffic times.
- the problems appeared when the system was running for a while.
- I got an XP 32 bit system with an intelE8400
harvey
Ups, a part of my answer cut....
Its now about one month that i deleted my data, and it is still quite ok.
Starting planes from my nearby airport (cologne) show up on the map from about 900 to 2000 ft.
Landings i can track about 100ft above touchdown.
before that the starting flights sometimes took minutes to show up on fl 80 or even later.
harvey
Bounty
I have a somewhat similar problem.
In myflights I see no local commercial traffic at all landing or taking off from Guernsey on the map.
All the aircraft appear in the left hand list panel and a picture of the plane is shown at the bottom.
Some of the local traffic may not be equipped with the right gear but most aircraft are new in 2010.
My antenna is only about 3 miles from the airport and I see all the passing longhaul with no difficulty.
The annoying thing is that most aircraft can be seen from my window.
anybody got any ideas.
Bounty
