3d aircraft MODELS
Started by rashers, March 02, 2011, 09:32:21 PM
andrewarles
Screenshot after installing the latest NavData.db3.
All 3D models have disappeared.
16 NM SSW of LFMV (Avignon)
27 NM NW of LFML (Marseille)
Arles, France.
Pinza
Quote from: AirNav Development on March 10, 2011, 12:16:20 AM
Try this one:
http://www.airnavsystems.com/Download/ANRB/DBUpdater/ANRBDBUpdater20110225.exe
Many thanks AirNav - have just downloaded and installed the updater you pointed me to.
This has given me back correctly rendered 3D skins for at least easyJet and Ryanair. Will monitor the situation for any missing skins that I used to have.
Attach screenshot.
Chris
Pinza
Hmm, A6-EBV just overflown my house on flight UAE38 - the evening Birmingham to Dubai flight.
Has reverted to a grey 'skinless' version - has always had a full skin until I installed latest updaters!
Is it related to the fact that the aircraft type is showing as B77W rather than B773?
rashers
yeh i have the 737 back but not the big ones 777 747 330 etc
cool_1
Hi Airnav,
any updates on a possible 3D fix please ?
My 3D interface is really unusuable due to this bug (and also a previous bug which I reported a year ago,  where I cannot select aircraft on the 3D google map, and still no fix ...ie. Airnav support ticket #76559).  I therefore have to select an aircraft on the 2D display (works fine), and then switch to 3D...only to see a white stalk or blank aircraft after all the hassle.
Its rather frustrating after paying good money for a 3D upgrade, and cannot use.
thanks
Pinza
Earlier today I downloaded and installed http://www.airnavsystems.com/download/ANRB/DBUpdater/ANRBDBUpdater20110313.exe
As documented on the thread relating to this updater, it installed in wrong directory - however successfully copied it across to where it belonged and have been running it for a few hours now.
I'm fairly happy with it but still have a problem with 'grey' planes flying around the Midlands!
It appears that I'm not alone with this problem - just wondering whether it is worth starting a new thread for missing skins? By this I mean a dedicated thread for missing skins with the details of the airframe that is missing - rather than a vague moan that I'm missing loads...
This might be more useful to AirNav to narrow down where the problem lies - any thoughts?
Before I (or anyone else) starts such a thread, this is what I am missing this evening:
HB-JVF F100 4B19EB Helvetic
G-OOPT A320 400953 Thomson
G-TOYK B733 401122 BmiBaby
LN-DYB B738 478538 Norwegian Air Shuttle
HA-LPI A320 473409 Wizz Air
EI-RJR RJ85 4CA4C3 City Jet
A6-EBV B77W 8960DD Emirates
All of the above created a correct 3D image but grey - ie no livery.
Certainly my Emirates flights always used to show correctly before I started updating my Nav.data.db3 file !!!
ACW367
Quote from: Pinza on March 19, 2011, 09:05:56 PM
There is certainly a bug that needs urgent attention.  But most of the examples you give will not have skins because Airnav never created them!
HB-JVF F100 4B19EB Helvetic - OAW F100 skin never created by Airnav
G-OOPT A320 400953 Thomson - TOM A320 skin never created by Airnav
G-TOYK B733 401122 BmiBaby - Airnav created a B733 for BMA (the main airline). The last B733 left that airline in 2007, 3 years before the creation of 3D.  They did not create a skin for bmiBaby BMI B733
LN-DYB B738 478538 Norwegian Air Shuttle - NAX skin never created by Airnav
HA-LPI A320 473409 Wizz Air - WZZ A320 skin never created by Airnav
EI-RJR RJ85 4CA4C3 City Jet - Airnav created a B463 for BCY. The last 146-300 left that airline in 2004, 6 years before the creation of 3D.  They did not create a skin for BCY RJ85
A6-EBV B77W 8960DD Emirates - Airnav created UAE skins for the other three 777 types operated by the airline B772, B773, B77L. But never created a B77W for any airline.
If you look in the GE models folder in your Airnav folder on your computer, you will be able to see which of the aircraft types should show a skin.
Hope this helps you identify which ones should not be blank and have a bug against those that were never created with the original 3D release.
Regards ACW367
Pinza
Thanks ACW367,
Rather late - and must a-bed - will re-read your reply when I'm fresh in the morning!
Sounds like the latest NavData.db3 update has nothing to do with my problems - just missing skins from the original 3D release!
Will play with copying textures into new folders under my GE models folder. (Having backed everything up first!)
Chris
#39
Quote from: ACW367 on March 19, 2011, 11:23:30 PMIf you look in the GE models folder in your Airnav folder on your computer, you will be able to see which of the aircraft types should show a skin.
If this helps.  Here's a list of each aircraft type with associated Flight IDs that will generate a 3D model with airline colours:
A300   FDX KAC MON QTR UPS
A306   FDX KAC MON QTR UPS
A310   FDX KAC PIA RZO SBI THY TSC
A318   AFR FFT MXA ROT
A319   AAF ACA AFL AFR AWE AZA BAW BER BMA CCA CNT CYP DLH EZS EZY FFT FIN GWI IBE ISS LHI MXA NKS NWA SAA SAS SBI SHT SWR TAM TAP TAR UAL VRD
A320   AAF ABY ACA ACM ADR AFL AFR AIC AJM ANZ AUA AWE AXM AZA BAW BER BGH BMA CIB CSA CSN CTN CYP DAL DLH EDW EEZ EIN EZY FCA FHY FIN GWY IBE IWD JBU JKK JST KFR LBT MON MSR MXA NLY NWA QTR RJA RZO SHT SWR TAM TAP TAR TCW TCX TGW THY UAL VIM VLG VRD
A321   AAF ABY ACA ACM ADR AFL AFR AIC AJM ANZ AUA AXM AZA BAW BER BGH BMA CIB CSA CSN CTN CYP DAL DLH EDW EEZ EIN EZY FCA FHY FIN GWY IBE IWD JBU JKK JST KFR LBT MON MSR MXA NLY NWA QTR RJA RZO SHT SWR TAM TAP TAR TCW TCX TGW THY UAL VIM VLG VRD
A332   AEA AFR ALK BER CES CSN EEZ EIN ETD EVA JST KLM LVG MON MPD MSR NWA QTR SWR TAM TAP TCX THY TSC UAE USA
A333   ACA AWE CAL CES CPA DAL DLH EIN GIA HDA IWD KAL LTU MAS NWA QFA QTR THA TSC
A343   AFR ALK CES DLH FIN IBE MAU MPD SAA SAS SWR TAP THT THY UAE VIR
A345   ETD QTR SAA UAE
A346   DLH IBE QTR SAA THA VIR
A380   AIB QFA SIA UAE
AT42   CAV CFS MTN
AT72   EFG
B462   AEE BCY BEL BLF BRT DLH FLI SWR
B463   AEE BCY BEL BLF BRT DLH FLI SWR
B717   HAL MEP TRS
B722   AJT CCI CJT FDX KFA
B732   AAH ANT BHS FAB PCE
B733   AEE AUI AWE BAL BMA COA DLH EXS FPO GMI JAT KAJ KNI LZB NAX OAL ROT SWA TAY UAL VEX
B734   ADH AEE AEW ASA AUI AWE BAW BEL CSA OAL SHY TSO VEX
B735   AUI BRU BTI COA DLH LGL LZB SWA TAR TVS
B736   BRA DAH MAH SAS TAR WJA
B737   AAH AEU AMX ASA AUH AZI BER BRA CCA CDG CES CGN CHH CHP CMP COA CSH CSN CSZ CUA CXA CXJ DAL DAN DNV EZY FJI GLO GMI HHI HLF HLX JAI KQA LCD LDA LGL MAH OMA PTI RAM ROT S2 SAS SCX SEY SNG SWA SXS TRA TRS TSO VOZ WJA
B738   AAL AEA ASA AUA AXB BER BSK CJA COA DAH DAL ECA ELY GSM HLX JAI KLM KYV LDA MAH PGT QFA RAM RYR SAS SCX SWG SXS THY TOM TRA TVS VOZ WJA
B739   ASA COA KAL KLM
B742   CKS EIA GTI NWA SVA
B744   AAR AFR AIC ANZ BAW CAL CCA CLX CPA CRL DAL DLH ELY EVA GTI JAL KAL KLM MAS NCA PAC QFA SIA SOO SQC SVA THA UAL VIR
B74F   CLX GTI JAL NCA PAC SIA SOO
B752   AAL AEU COA DAL DLH ERO EXS FDX FIN ICE MON NAO OAE SXS TCV TCX TOM UAL UPS UZB
B753   AIZ CFG COA DAL ICE NWA TCX
B762   AAL ABX AWE COA ELY TPA TSO USA
B763   AAL ABX AFL ANA AWE AZA BAW BPA CCA CFG COA DAL ELY ETH GSM HAL JAF JAL LAN LOT MON MPH NAO RAM TOM TPA TSO UAL UPS UZB
B764   COA DAL
B772   AAL AAR AFR AIA ANZ AZA BAW CCA COA CPA CSN DAL ELY HVN JAL KAL KLM KQA MAS MSR PIA SIA SVA THA UAE UAL
B773   ACA AFR ANA CPA ETD EVA KAL SIA UAE
B77L   ACA AFR ANA CPA ETD EVA KAL SIA UAE
CRJ2   ASH AWI CAA CHQ COM FLG JIA JZA MES SKW
CRJ7   ASH CAA COM EFG GJS JIA QXA SKW
CRJ9   ASH COM FLG FRL JZA MES SKW
DC10   AFL APW CIU FDX OAE WOA
DH8A   AIE BHS CJC CRQ ERH JZA LGL LIA MKU PDT POE QXE SSX USA
E120   GLA SKW
E135   CHQ EGF
E145   ASH CHQ COA EGF LOF SLI USA
E170   RPA TCF
E190   ACA AWE JBU VOZ
F100   AFR AUA KLM OAW PGA
F70    AUA KLM MAH
IL96   AFL CUB
MD10   AFL APW CIU FDX OAE WOA
MD11   AFL DLH FDX FIN GEC KLM SVA UPS WOA
MD83   AAL AAY BUC DAL OHY
MD90   DAL SVA
Pinza
Thanks for that list Tarbat - it appears that my grey planes aren't in it - explains a lot!
Chris
