Author Topic: Network down again!  (Read 21175 times)
Re: Network down again!
« Reply #30 on: May 20, 2011, 01:24:36 PM »
We are aware and doing our best to get it back up.
We did change the server software earlier this week to handle the increased the load on the server. As mentioned in that post we were checking and monitoring it to make sure it can handle the increased load for the future.
« Reply #31 on: May 20, 2011, 01:40:02 PM »
Thanks for the prompt reply AN (as always!).   Good to know you're on the case - the link to Network status, still comes up as a blank, this needs to be sorted so it works - that would save us having to check our equipment is working properly.   Many thanks and regards to all the team.
« Reply #32 on: May 20, 2011, 01:52:57 PM »
In case you haven't noticed, the rest of the site is coming up like that. Only the forum is staying up.
« Reply #33 on: May 20, 2011, 02:05:57 PM »
Well done AN, network back up 1405 UTC!
« Reply #34 on: May 20, 2011, 02:12:38 PM »
Back up and running.
Evanelpus
« Reply #35 on: May 20, 2011, 07:00:44 PM »
If it goes down again go to FlightRadar24 until AN sort things out, it's live and pretty good.
« Reply #36 on: June 08, 2011, 08:27:27 PM »
Network appears down again
    • Rod's RadarBox Downloads
« Reply #37 on: June 08, 2011, 08:35:46 PM »
And the Status page is down, too.
ACW367
« Reply #38 on: June 08, 2011, 09:08:15 PM »
Yep - down again.  It seems more fragile at the moment that at any previous time over the last 3 1/2 years.
No doubt at some point before dawn Airnav will hit the reset button. At least without the network the number of alerts I recieve might go up slightly.
« Last Edit: June 08, 2011, 09:10:49 PM by ACW367 »
« Reply #39 on: June 08, 2011, 09:09:02 PM »
We are taking a look.
« Reply #40 on: June 08, 2011, 09:19:17 PM »
Should be back up in a few minutes. Sorry for the inconvenience.
« Reply #41 on: June 09, 2011, 12:18:51 AM »
We have noticed that this problem is happening every Wednesday at the same time leaving the network server down for 1 hour. We are continuing our efforts to find out what is causing this.
