RadarBox 2008 - V1.5 - Ready for Download
Started by AirNav Development, March 19, 2008, 02:37:28 AM
Roadrunner
AirNav,
Referring back to my mention of grey lines across the screen. I have re-started without recorder running and after a time I am getting a grey line across the screen about 1/10th of the way up the screen and always the same orientation and approx 1 inch wide.  It seems to be flickering in time to a pulse of some sort ? very weird and I have not seen it referred to in any other threads.....
Dub33
Hi AirNAV \ All
I had numerous problems with V1.4 and the updated V1.5 e.g screen freezing \ slow response times etc. In an act of frustration, i deleted all AIRVAV programmes off my PC and then reloaded only the updated V1.5.
I've had no problems since then....running like a dream
Good work on V1.5 by AirNav
Dub33.
#77
Quote from: Roadrunner on March 21, 2008, 02:38:03 PM
AirNav,
RoadRunner,
I don't remember reading that post.
Does this happen as soon as you run RadarBox, or is it after you have changed maps or changed to full screen?
Does it look like this?
#78
The recorder is obviously having an issue after while which is causing the updates to work correctly and hence you might be seeing weird affects.
Anyhow we have established that recorder is the cause so please do not run the recorder and post posts about whats its doing as we already know and working on it :)
Development here. Recorder problems copied and we are already working on them.
davis
#80
AirNav,
I have this problem for a long time, but just what they have not given importance.
Operation perfect from this morning without recording .. Now active recording and see what happens....( Just to pass the time and not to protest if this fails )
I think that the 1.6 will 'perfect....After  how are will  going to pass the time if there will be no more' problems?
Gianni ---- XP PRO
marcdeklerk
Airnav, could you possible add a function whereby the "trail lines" remain on? at the moment we can only select "seconds" to remove them.. I have mine set to 10000 but after a few min they Disappear.
Thanks guys.. keep up the good work!
<M>
Roadrunner
AirNav,
Just thought I would let you know I have had my RB on since 07:00 this morning and just switched off at 19:30. Network engaged all day and downloading pictures. Network traffic peaked at over 700. I have had not problems and that makes me very happy as the only problems I have had are the recording ones (yesterday) and you are working on that.
Thanks..
Bigyun2000
AirNav
Unlike Roadrunner. I have had error in Vista Home Premium. RB Was on from around 8am thru till 8pm. Had 2 not respondings.
Attached is the screen shot.
[attachment deleted by admin]
Bigyun2000,
Thats weird, the forum went very quite with issues with application crashes once we said not to use recorder. Can you confirm you were not recording or playing a recording?
Also any internet drop outs during the day?
Bigyun2000
Yes i had recorder on.  Will try it off.  Sorry i should have read the forum first.
Tony
CarlosAbreu
Hi to all
I have install the v1.5 in my new HP Vista based PC and after 24H ANRB still working with the networking connected without any problem detected.
Have a nice Easter.
Brgds
CA
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
f6gsg
hi All,
i was very frusted because, i was not at home, and i can see that there is
new version 1.5 and i can't test it !!!!
so, i'll back and i immediatly test it.
Good news, no slow windows, all is well (without recorder On and local time
for the log), if i put recorder on, freezing about one hour !!!!
Bad news, i have a new "problem", a blue screen with this message:
DRIVER_IRQ_NOT_LESS_OR_EQUAL
FTDIBUS.SYS
B98A9CF4 STOP 0x000000D1
if i have more than the radarbox active i can have blue screen about one or two hours.
(especialy if i use FTP transfert and Flight Simulator !!!)
i have re-install (after kill it) the driver FTDI.(the old one on the disk)
i have change the port bus.
i have put an USB card extension with another chip(Nec)
no success...
And not with the 1.4 !!!!!
My computer is a DELL 2.8 Ghz - 3Go Memory, XP PRO (SP2) and on the USB the Keyboard, the mouse and a printer ...
AirNav a research Track ?
Patrick / F6GSG
Open up RadarBox 2008 and then go to Help -> About and tell us what your firmware says.
Regarding recorder, we know the issue, its stated in the posts above.
Lastly we do not recommend you use RadarBox and Flight Simulator at the same time. Flight Simulator is a high end application (requires lots of resources) which can lock up your machine (temporarily) anyway when loading screens.
Patrick,
Also, what version USB driver are you using? The driver on the disk might not be the latest version - there was an update vis the forum - for V1.3?
It should be 2.2.4.0
