Hi Chris,
AD6415 decodes to N962FD which is showing on the FAA website as reserved by FedEx
chewycanes
Evening Alan
0063B5 Using incorrect code (from AF)
469076 SX-DCV no data (from GA)
740732 JY-AYR A320 Jordanian Airlines (from GA)
4C8048 No data
Brian
X
I have been informed that 89632D is A6-ABM A320 airarabia returning to UAE
89623C as yet unconfirmed but likely to be ex A6-ABU/CN-NMD as stated before.
X
X
Quote from: chewycanes on September 21, 2011, 07:25:05 PM
Evening Alan
4C8048 No data
Brian
Brian
469076 SX-DCV  Da7X c/n 111 Executive
X
X
Another Chinese not populating
7806AB China Unknown
Do you hex codes for the following which are not in my db?
B-2135  B734   CYZ
B-2284  A321   CES
B-2501  B734   CHH
B-2513  B734   CYZ
B-2535  B733   CCA
B-2827  B757   CSN
B-2893  B734   CYZ
B-2897  B733   EPA
B-2936  B733   CSN
B-2971  B733   CSZ
B-5031  B73G   CES
B-5571  B738   OKA
B-6747  A320   CHB
B-6748  A320   CBJ
B-6763  A320   CHB
B-6783  A320   CSN
B-6795  A320   CBJ
X
X
89632D has been in the d/b as A6-ABM since late August
Hi Brian,
0063B5 unknown
469076 SX-DCV, Fassault Falcon 7X, c/n 111
740732 JY-AYR A320-232, c/n 4817, Royal Jordanian Airlines, added on departure from Toulouse
4C8048 unknown
X
#1447
You are right I have picked up everyday since 27/8/11 when I returned from Russia, had not noticed due to being an old reg! Previously it was 8961F5 and always showed up as a H748!!!
X
X
B-2135  78057E
B-2284  79A053
B-2501
B-2513
B-2535  780080
B-2827
B-2893
B-2897  unknown
B-2936  79A030 A320-232 c/n 1057 China Southern Airlines
B-2971  7BB045
B-5031  7BB0C9 Boeing 737-79P c/n 28255/1284, China Eastern Airlines
B-5571  78072D
B-6747  unknown
B-6748  unknown
B-6763  780725
B-6783  unknown
B-6795  unknown
X
Thanks a lot for the Chinese
X
chewycanes
#1450
Morning Alan
Thanks to you and X for your previous posts
503CC4 LY-SKC YAK42 Aurela (from GA)
3B7739 FAF XINGU (waiting to see if Modes comes up with a result)
Brian
EDIT : From ModeS 3B7739 is Xingu ser no 072.
X
Not populating
C0613E  G5K9461
E48A32  RV 08
X
Evening Brian,
503CC4 is now CU-T1708 with Cubana since early last year, did you see this on the network?
X
C0613E, Bombardier BD-700-1A11 Global 5000, c/n 9461, Bombardier Inc
E48A32 unknown
chewycanes
Evening Alan
No it was not on the network.
I normally check to see if it looks like a possible corruption before i log it with you.
It was the only code with 503CC* that day and normally i might see something similar at the same time so i know it a corruption.
The msg count was only 16 @ 33000ft so it may just have just been a corruption.
I will let you know if it returns.
Brian
