X
Andrew
More Chinese codes picked up that are not in my d/b
7BD2B6
7B0378
7B006C
7800B3 possible miscode of B-2538 (see below)
780083 B-2538
7800B4
7800B5
7BA0DE at FL310
Question, do have you any reports on Chinese miscodes with letter B misreading as 8 and D as 0?
X
Bob SEN
Hi all
758225 s/be RP-C3264  A320-214  c/n 4852  Cebu Pacific Air just seen ott on delivery........
cheers
Bob
1/2 a mile South of EGMC/SEN
tommyg
Hi Guys.
Over the past couple of weeks have picked up Challengers OE-INE/G/H operated by Vistajet with no acft type showing. I can remember having to update manually on the previous database as well.
Tommyg
Tommyg
orkney
Hello Ingo, X, Bob
All the ones you provided details for are added. I can find nothing for the others.
Tommyg - They are all fine in the database.
Thank you
Andrew
X
#1624
Andrew
78071E CES5329 Not populating I am informed is B-6755 A321-231 China Eastern Airlines c/n 4746
X
anorak
Not populating;
OE-GVJ    Learjet    60   LJ60   60-359    L2J    HQCE    4403DE   VJS - VistaJet   2008      2008-11
Dave. Exmoor, North Devon.
orkney
Hello Ingo, X and Dave
I did add D-CMMM the first time but for some reason it didn't get onto the database. It is on now though.
OE-GVJ and B-6755 are added now
Thank you
Andrew
Bob SEN
Hi Andrew, just popped up on mine is 47180E n/p Airframes shows it as HA-FAM B1900
Bob
ACW367
Quote from: neroon79 on September 29, 2011, 08:12:25 PM
Evening, this time I have a quite unusual Database request:
With next release please add the following Airport:
KPVG Hampton Roads Executive Airport / Norfolk, Virginia, USA (http://www.airnav.com/airport/PVG)
Thanks.
Quote from: neroon79 on September 30, 2011, 05:37:17 AM
Additional question/request: I think, that it may make sense to use this thread as central "station" for any kind of other Database requests, like errors in Airport Data, missing Airports and any other topics that don't come to my mind at the moment. What do the "Updaters" think about using this thread as central point for any kind of database update requests?
It would be better to start a new post for these.  The database updater team only have access to the aircraft.  Any amendments to the other tables in Navdata can only be done by Airnav Development ie Airports, Airline codes, ICAO aircraft code, Routes etc.
As such us updaters cannot action your request above.  If they are left in this fast moving topic, when development look to the next Navdata release, this type of request will be difficult for them to find.
For new or added Airports, I believe the lat/long in the format used for the other airports in Navdata is also required as this derives the spot where the label is placed.
The Navdata Airline code table in particular has only had very minor cosmetic changes implemented by Airnav Development since it was first created when the Radarbox was launched and it is woefully out of date.  Many long defunct airlines are still on the list, whilst many airlines currently seen on the network, do not feature on the list.
Hope this helps
orkney
Hello Bob
That one now added. Thank you
Andrew
anorak
Perhaps AirNav could sort a method to receive DB updates so that they can input the amendments.
Dave.
Quote from: ACW367 on September 30, 2011, 11:54:48 AMHope this helps
Yes it does.
Well, the same will happen, if this new post won't be pinned to the beginning of this Forum. It will vanish into the dozens of other "small" threads started in between. And as usual (almost) no one will use the search function to dig out this "old" request to add the next. If "we" start a thread about other database requests, it should be "nailed" to the first page of the Forum. Naming could be "General Database requests e.g. missing/wrong labelled airports..."
I agree with you, that it will be an enormous effort to go to the DB update Thread to find the general requests, but at least you only have to go through one thread and not through many fragmented over the whole Forum.
In this sense: Airnav crew, is it possible to establish the mentioned kind of "fixed" post on the first page of this sub-forum?
I know, how to add an airport -did this several time in the past- , but thanks anyway. The intention was, to still have the particular Airport in the Database after the next Update release.
Enough about this detour, back to topic.
Quote from: anorak on September 30, 2011, 12:07:27 PM
Dave.
This would be too easy. Nice idea anyway, although some one on the airnav end must/should check the received amendments. Why? Because there are many "strange" people on this planet, who may add a lot of non sense to the db if they get the chance.
54901 - Jim
Owner/Operator updates for you, Andrew!
A4EF65 / N417NZ - Global Jet Leasing Inc
A57089 / N45HV - KRS Holdings LLC
A629B8 / N4967M - Warren A Pietsch
A5B76E / N468BB - Ricky Lee McClanahan
A52D53 / N4323F - Richard J Mason
A55C5E / N4444A - Chris E Wesolowski
A4EF0A / N417KH - DV Trading Inc
A58C38 / N457BB - Angelina Aviation LLC
A5204A / N4296T - Christopher M D'Haem
A50F2F / N425LC - QT Aviation LLC
A44593 / N3744H - Steve W Roberts Jr DBA
Thanks!
KOSH - Oshkosh, Wisconsin USA
