I checked the Log of my secondary Box, and wasn't able to find 400CFD. So it's possible that it was a decoding error on the primary Box.
X
Andrew
Rats...an AN140 and I didn't see it, the first one ever noted here!
X
X
Andrew
Indian AF An-32's 800319, 80031A, 80031B, 80031C & 80031D
The serials  are K2689, K2704, K2707, K2708 & K2719
But order unknown. ALL routed Riyadh-Muscat last week
X
X
Andrew
Not populating
ACA5C2 f/n N914CJ
x
X
Andrew
076C94 Not populating on approach DXB
X
orkney
Hello X
I have found this on google/live-mode-s so have added them. I have also added N914CJ
80031D An-32 (K2719) 80031C AN-32 (K2708) 80031B An-32 (K2707) 80031A An-32 (K2704) 800319 An-32 (K2689).
Thank you
Andrew
orkney
Hello X
I can find nothing for 076C94 and it isn't allocated to a country.
Thank you.
Andrew
X
#1687
Andrew
As I could not see it, I just hope the flight number given later is not a clue to what I think it might be.....Jordanian Air Force IL76MF ex Russia 76954???
*076C94  f/n 76954  Not Allocated 2011/10/03 01:46:18 climbing from 4000ft  thru f/l 100 departing UAE
X
orkney
Hello X
I think you could be right but I cannot find anything confirming it.
Thank you
Andrew
Horsham Spotter
Good morning Andrew.
One found this weekend not populating.
402F1B , G-LUSK , L8 , Luscombe 8A , Mark Alan Lamprell , 3795
Hope of use.
Steve.
3.1nm miles south of EGKK westerly App & Dep.
orkney
Hello Steve
That one now added also. Thanks again
Andrew
Chris11
orkney
Hello Chris
That one is added now.
Thank you
Andrew
chewycanes
Morning Andrew
A6B26C callsign N530WL B737 WILLIS LEASE FINANCE CORP (from FAA)
A880DC N647SR B737 SOUTHERN AIRCRAFT CONSULTANCY INC TRUSTEE (from FAA)
3E191E D-IASC PA31 ? (from AF & GA)
Brian
orkney
Hello Brian
All of them are now done.
Thank you
Andrew
