0 Members and 6 Guests are viewing this topic.
Quote from: Runway 31 on June 29, 2011, 01:34:44 PM
I suppse the only way for any degree of certainty is visual confirmation.
Agreed. Preferably with the Camera in the right hand and the Labtop/Netbook (running ANRB or any other virtual radar) in the left.
That should just about be enough!
knight01
Nothing showing for 406543 in G-INFO
chewycanes
Hi Alan
406543 is G-EZUJ A320 Easy Jet  on delivery i believe. (from modes forum)
Brian
#185
Thanks Brian
Been busy beavering away and havent been on anywhere else.  Still probably wouldnt have got it as it was on 2 days ago.  Its A320-214 c/n 4740
Also on delivery courtesy John Hargreave are
4CA973 EI-IMM A319-111 c/n 4759, Alitalia
3985A6 F-HBNG, A320-214 c/n 4747, Air France
#186
Thats G-EZUJ now noted on the SBS forum on its first revenue service
Also courtesy John Hargreaves, also on delivery from Airbus are:
4BAA53 TC-JRS, Airbus A321-231 c/n 4761, Turkish Airlines
8962E3 A6-AFE, A330-343E, c/n 1226, Etihad Airways
Busy day.
From Wednesdays Log:
3B77A2 (France / Flight id CTM2080 / CTM: Armee de l'Air Francaise {France Air Force ?})
3E7217 D-KIKD DIMO HOAC HK-36R Super Dimona Private
3E962C (Germany MIL / Tactical / flight id: EAGLE1)
3EAD04 (Germany MIL / Tactical / flight id: BU12T)
3FA2F5 (Germany Air Force / Tactical / flight id: GAF032)
3FEBD5 D-MPSH DV1 Dova DV-1 Skylark Private 07/09 http://www.abpic.co.uk/photo/1291154/
3FEC53 D-MSDK BREZ Aerostyle Breezer C Private (http://www.flugzeug-bild.de/1024/breezer-cd-msdk-auf-dem-flugplatz-32215.jpg)
406543 (flight id: EZY8001)
44CE76 (Belgium)
4786F8 (Norway)
48AD0F (Poland)
4BAA53 (flight id: THY6902)
4CA973 (flight id: AZA8921)
A48449 N390RJ PRM1 Hawker Beechcraft Corp 390 Premier 1 Bank Of Utah Trustee RB-220 (http://www.aircraftone.com/aircraft.asp?tn=N390RJ)
That's all from Wednesday.
chewycanes
Hi Biran,
87-0028 has an allocated hex of AE0579 but I note from Airframes tha tthis aircraft has one of its transponders miscoded as AE050D so I will add it to the d/b as a miscode.
Hi Ingo,
For the THY, EZY and Alitalia unknowns see the 2 replies above your query.
3B77A2 unknown
44CE76 unknown
47868F LN-AKH, RV4 c/n 2751
The mil tac codes unknown
mikek
7C7C74, VH-YVA incorrectly entered as VH-YHA.
Everything else looks correct
Thanks,
Mike
Hi Alan, it seems that you need a vacation quite urgent.
The ICAO24 from Norway that I've posted was 4786F8 and not 47868F.
About the three unknowns: Already noticed them. That's why I've reduced the Info to HEX and flight id only.
Except the feeding of the AT Bug I don't do any manual updates to the Database any more. I'm using the populate function and the download of the new database update files. That's the easiest way to notice new or previously unprocessed unknown Airframes, that I can try to track down and post theme here to be added to the Database. I think this is the best way to keep my DB and the "global" DB synchronised. Especially if my local db gets somehow corrupted.
Cheers Ingo,
4786F8 is LN-AKH as posted, sorry about the finger trouble, the d/b entry is correct though.
I'm off to Spain next week for a few days and I will hopefully use Radarbox as it its designed to be.
