X
Still about 12 US - Marine Corp instead of Marine Corps in db
Check Zimex Aviation a few variations are in there.
X
Thanks X
Nothing on your miscode
Blueboy
Hi Alan, I had AE0166 on the box last week - database says its N770GA - It arrived at Prestwick as 86-0201
J.D
Hi JD, it seems to chop and change between one and the other to suit its needs , its on the FAA site as N770GA but that should decode to AA699E.  I have been following the discussion on the mode-s forum and have assigned it the miltary serial 86-0201 against AE0166.  It is also in the d/b under hex AA699E/N770GA
Blueboy
Hi Alan, No one said the job was easy :)
J.D
John Hargreaves
Alan,
Two out of Finkenwerder -
780310 B-6845 A321-231 c/n 4923 Sichuan Airlines  -  CSC6845
E8042A CC-BAT A320-214 c/n 4921 LAN Airlines  -  LAN9901
John H.
John Hargreaves
Alan,
A7B001 N595AG on now over Texas showing B737-4S2F instead of B737-4S3F
Several variations in the AC column for Garuda Indonesian Airways at the moment.
John H.
X
#2708
Quote from: X on November 13, 2011, 04:09:26 PM
Unknown hex 760019 is believed to be 10025 Saab 2000AWACS Pakistan - Air Force at DXB show (I believe this means it c/n 025)
Will confirm
X
760019 confirmed on flying yesterday.
4148 C130 Pakistan - Air Force has been noted and should be hex 7610D6.
db states 763987 C130 Pakistan - Air Force reg is 12747, should now read 4282.
IL76 c/n missing in d/b for 50FF5E (miscode) should be R10-002 IL78 Pakistan - Air Force 00734 76277
X
X
* ADA608                                                              2011/11/17 11:42:14
At steady 1000ft so would assume an eggwhisk
X
Thanks X, good ones.
ADA608 N797KU, Bell 412EP, c/n 36564, Bell Helicopter Textron
anorak
340004 / A5BAA  nothing on Airframes.
Thanks,  Dave.
Dave. Exmoor, North Devon.
Dave,
A5-BAA Pilatus PC-12/47E c/n 885 miscoding
diddyboy
Some not populating and updates from Sudan.
6835C1 UP-I7642 / IL76TD / 0063471147 Air Almaty (poss Mis-code) noted today at El Fasher
064565 NAF565 / Super Puma AS.332 M-1 / 2239 / Nigerian Air Force noted at El Fasher 12 Nov 11
508055 UR-42426 / YAK-42D / 4520423304016 / South Airlines on Lease to TARCO Air.
Neil
