#2745
lebelgepatte,
Having asked the question on the mode-s forum re the , the following was received from Trubb
I have 44F643; 44F644& 44F645 respectively for these three Sea Kings,
> > but note that the Belgian military seem to have inadvertently doubled up
> > on these codes as they were already in use by Agusta 109s H29; H30& H31
> > before being subsequently allocated to the Sea Kings.
> > Looking at recent reports of the hex codes (and their Mode S flight
> > IDs/callsigns) on Albert's site indicates that all three codes appear to
> > be still in use by both the Sea Kings& Agustas.
> > In summary...
> > 44F643 = H29& RS03
> > 44F644 = H30& RS04
> > 44F645 = H31& RS05
> > and for the sake of completeness regarding the Belgian Sea Kings...
> > 44F642 = H28& RS02
And from Andy
I can confirm that these are dual usage codes - 2 with same code at EBBE the
other day and that is not uncommon.....Andy
I wish I hadnt asked!!!
X
#2746
VP-BKA has not taken off yet, nor did it as D-AKAS, all changes on the ground!
PS Looking at last post re Belgium , I thought I had problems!
X
Thank X, I,m sure it wont get past you undetected, not with the view from your window!!
X
If it takes off over desert I do have problems!
X
paul tricker
This mis-populated I think..
AE2BEC    166659  MH60  US - Navy
I think it should be 166569
Paul
Thanks Paul, the other one is a Hornet.
X
Alan/Paul
Photo of it shows it is indeed MH60 166569.
4148 C130 Pakistan - Air Force confirmed as being as such again today.
X
X
This must have been at show but have not yet tied it up
31FF05                                                              2011/11/18 11:46:34
X
X
31FF05 decodes to I-PDVS, cant find anything on that registration but the previous holder is now VP-CYA, Piaggio P180 Avanti II, c/n 1166, Saraya Holdings
ACW367
The scramble forum gives that Avanti CN 1220 was at the Dubai show with I-PDVS test/delivery registration. http://forum.scramble.nl/viewtopic.php?p=537849&sid=f68ec8ba0d99da21aed434acc4b2124a
Thanks ACW, marked as such in d/b
X
ACW367/Alan
Yes it was at show with reg I-PDVS
Eyeballed both Pak Hercs definitely 4148 and 4282 as stated
X
X
Not populating 398924 FHCJE OTT Brazil at 41000
X
Last reported by you 10/11 X, still nothing known.
