anorak
#750
A33E2E / N308MS in data base
Cessna    550 Citation Bravo   C550   550-0976    L2J       A33E2E   Aircraft Guaranty Holdings & Tr.   2001      2008-01-11   N308CS   2008   OE-GML   reregistered   edit
in Airframes, flying over Cornwall at present.
From the pattern he`s flying I would think that it is on air test.
Dave. Exmoor, North Devon.
Hi Dave,
The database is correct A33E2E, N308MS, Boeing 737-3L9, 27336/2587, WFBN ex LN-KKT out of Lasham.
Registered 26/7/2011
chewycanes
Evening Alan
I left this one a day or two to see if modeS forum came up with a result but they have not as yet.
38A0FC Callsign FJRMT
Brian
anorak
Thanks for the confirmation, went overhead but above the cloud.
TTFN,  Dave.
X
#754
Did not populate, but read off however difficult to be exact when zero is plotting!
* 8A0286  LNI152   WIII-WSSS       PK-LHT  B739  Lion Air             2011/07/29 08:52:13
   8A0285                                      PK-LHS  B739  Lion Air
   704943                                       XY-AGL A320
   78072F                                       B-3570  CRJ    white
x
Morning Brian,
For these codes, I believe they are allocated as a radio callsign to the pilot and not the aircraft.
#756
Morning X
8A0286 PK-LHT, Boeing 737-9GPER, c/n 37283/3699, Lion Air, already in d/b
8A0285 PK-LHS, Boeing 737-9GPER, c/n 37282/3663, Lion Air, already in d/b
704943 XY-AGL, A320-231, c/n316, Myanmar Airways International is in the d/b
78072F, B-3570, Canadair CL-600-2B19 Challenger 850, c/n 8102, Yalian Jet is already in the d/b
Have you installed the latest Navdata ?
chewycanes
Morning Alan
4245FD VQ-BMN A319-111 c/n 2249 Sky Express on delivery (from ModeS forum)
Brian
X
#759
I populated and they came up later, but to answer you question, No, sheerly because over three years I am scared to lose all the changes I have made eg all the Hercs, C135's etc so on so forth.
On an other matter has anyone reported previously that Tiger and Silk seem to bang out two codes at once, one right one wrong, I wondered why in the dark I could only see one when two were reporting at exact same height??? I had to eyeball them all over again today. Everyone else is OK.
Had yet another Ground transmitter go ballistic to 68000, must thinks its an F16 from next door!!
X
X
#760
8A01EB PK-JBH H25
Is that in new db, if so I will change when I get back to home if convince me you have all C130's and 135's up too date!. It took me a year to get everything. including miscodes.
X
X
8A01EB, PK-JBH, Hawker 900XP, c/n HA-0071
No we didnt have it in the d/b but then again, I checked AvDb, Airframes, GAS and Libhomeradar and none of them have the hex associated with the registration. AvDb had all the details apart from the hex, none of the other even had the registration although you can get the aircraft non-hex details from google.
Never heard anything about Tiger/Silk before.
I wouldnt even try and convince you we had all C130, KC135's even although I am pretty confident and as far as miscodes go I would suggest you keep your own database of these and dont change.
You could go the populate route in Mylog and if you are connected to the net, if you click on an unknown and it is in the d/b it will down load into your Navdata.
Dont have any problems with sending me an email
X
#763
Still including ballistic ground stuff going to fl 680, plus some other unknowns that will just not update from My Log.
* 341504  SPIDER                                                      2011/07/29 06:15:43
* 750013                                                              2011/07/29 22:35:52
* 7500F6                                                              2011/07/29 14:05:08
* 7501D4                                                              2011/07/29 03:01:54
* 76E4C4                                                              2011/07/29 16:53:10
* 76E4C5                                                              2011/07/29 17:40:01
* 76E4C7                                                              2011/07/29 14:30:59
* 76E4C8                                                              2011/07/29 14:41:21
* 76E4CA                                                              2011/07/29 09:25:30
* 76E4CC                                                              2011/07/29 08:44:19
* 76E4CC                                                              2011/07/29 15:19:44
* 76E4CE                                                              2011/07/29 09:17:06
* 76E4CE                                                              2011/07/29 17:05:33
* 76EB02  R19                                                         2011/07/29 16:06:47
* 76EB08  R35                                                         2011/07/29 00:33:01
   76EB0A  ROVER2                                                      2011/07/29 07:26:40
* 76EB0B  R3                                                          2011/07/29 15:10:24
* 76EB0B  R3                                                          2011/07/29 19:49:16
* 76EB0C  ROVER4                                                      2011/07/29 15:52:27
* 76EB23  FT9                                                         2011/07/29 08:18:57
* 76EB25  FT 5                                                        2011/07/29 16:56:57
* 76EB27  AMB 1                                                       2011/07/29 06:07:36
* 76EB2B                                                              2011/07/29 18:36:16
* 76EB30  FT 10                                                       2011/07/29 08:48:21
* 76EB34  AMB 2                                                       2011/07/29 14:22:30
* 76EB47  RXTXS11                                                     2011/07/29 01:33:39
   76EB4B                                                              2011/07/29 15:17:44
   76EB4E  RXTXS20                                                     2011/07/29 13:18:11
* 8A00B9                                                              2011/07/29 04:10:24
* 8A016E                                                              2011/07/29 06:55:43
* 9A00B8                                                              2011/07/29 14:25:02
* C03E13                                                              2011/07/29 14:52:15
PS will send list by email when I get back to sun and sand
X
chewycanes
Afternoon Alan
4CA989  EI-ESG A319 Windjet on delivery (from modes forum)
4CA2DF EI-DMX B737 Aeromexico (from modes forum)
Brian
