Author Topic: Why does this always happen?  (Read 9525 times)
Re: Why does this always happen?
« Reply #15 on: July 17, 2011, 03:00:41 PM »
Hi X,
The database entry was incorrect thats why it reverted when you corrected it. I have corrected the info it in the d/b so you should be able to update it now.
BTW there is a database update thread http://www.airnavsystems.com/forum/index.php?topic=6224.0 where you can post any unidentified aircraft you pick up and we will add it to the database if we can find the info.  If you have the hex only that will do but if you have other info, even better.
You can also post mistakes in the d/b like you have just done and we will amend the data held.
« Last Edit: July 17, 2011, 03:02:12 PM by Runway 31 »
X
« Reply #16 on: July 17, 2011, 04:00:27 PM »
Thanks will also delete from photo's and see if that does the trick! does anyone have  tie ups for two IL76 that operate out of the UAE daily 60005F and 60006C
X
Aerotower
« Reply #17 on: July 17, 2011, 04:14:07 PM »
X
Please let's stop the off-topic.
Still have questions, create a topic or search to get him.
« Last Edit: July 17, 2011, 04:24:48 PM by Aerotower »
Aerotower
« Reply #18 on: July 19, 2011, 12:35:17 AM »
I made a short video to see what happens with my radar.
Also using the Windows Task Manager.
http://www.aerotower.x10hosting.com/aerotower/Airnav and download the .rar.
« Last Edit: July 19, 2011, 12:40:46 AM by Aerotower »
« Reply #19 on: July 19, 2011, 11:16:55 AM »
Hi Aerotower,
It might be an idea to email support directly in an attempt to get an answer mailto: [email protected]
Netcop
« Reply #20 on: July 19, 2011, 12:22:23 PM »
Yes, this issue exists, but probably it's a Radeon story. I have exactly the same picture when I pass between the full-screen and the screen with menus on my main monitoring PC which is i5/4Gb/Radeon 5850/Win XP Pro 32-bit.
I have tried to replicate this issue on my other PC - i3(integrated graphics)/4Gb/W7 Ultimate 32-bit but still no signs of "grey screen story".
Nick
Greetings from Russia, Moscow
20.54 nm NWN of UUDD
Amp: Wimo AS-1090
RadarBox24 station: Netcop
Aerotower
« Reply #21 on: July 19, 2011, 12:42:37 PM »
Nick
And what is happening in the video I did, the same happens to you?
Netcop
« Reply #22 on: July 19, 2011, 02:09:43 PM »
Yes, exactly the same.
Nick
Amp: Wimo AS-1090
