Author Topic: New Navdata.db3 - 20110925  (Read 16967 times)
Northern Watch
Re: New Navdata.db3 - 20110925
« Reply #15 on: October 02, 2011, 07:06:50 PM »
neroon79 & ACW367,
Thank you for the insight.  I have spent an inordinate amount of time in updating my database but find it is becoming increasingly difficult to maintain of late due to a change in my circumstances.  I have been following the work by the updaters with interest but was always reluctant to convert.  I think it is time to bite the bullet.
Keith
« Reply #16 on: October 02, 2011, 07:39:01 PM »
Keith, several month ago I was there, were you are now. I had Spend hours to fill my own Database with local airframes. And then it happened: Fatal hardware crash. Databases in use: terminated, Backup on other partition on same HDD: terminated. Unfortunately another quite actual Backup on USB drive was also corrupted. I had to go to a several month old Backup. All work until then: Lost. At this point I decided to take another way: Since then I post all unknowns with details I'm able to dig out to the Updaters. Preceding this way I'm able to get "my" airframes back even if all local back-ups are gone to nirvana.
Northern Watch
« Reply #17 on: October 03, 2011, 09:21:39 PM »
Hello neroon79
I know what you mean as it almost happened to me about a year ago.  Luckily my backup was only a few days old and downloading it did the trick.  The truth now is that it was becoming to big to maintain and I only had approximately 86,000 records of which their was still a considerable amount that needed checking.  I downloaded the update yesterday and used it today not that it got much use this far North but I had no problems with those I did manage to pick up.  Thanks again to you and ACW367 for your advice and considerable thanks must go to all the updaters.
Keith
ACW367
« Reply #18 on: October 04, 2011, 10:25:51 AM »
Keith
Thanks Keith.  As we said above, if you find anything on any aircraft record that you feel needs changing, let us know via the database update requests thread or the via PM and we will quickly look at them for you.
Northern Watch
« Reply #19 on: October 04, 2011, 08:31:15 PM »
Quote
Posted by: ACW367« on: Today at 11:25:51 am »
Hi ACW367
I have been monotoring a number of unidentified aircraft in mylog and spent a good hour or so trying to fill in the missing details.  The results have now been posted on the update tread.  Also working on a few more but finding them a little more difficult. I will keep trying but may have to call on you at some point.
Thanks again.
Keith
ACW367
« Reply #20 on: October 05, 2011, 02:24:17 PM »
Keith
If you post the remaining blanks that you have in the update forum, we will be able to assist you in the search for tie-ups.  As you can see from that thread, with regards to the German GA aircraft, it often takes the mark one eyeball of the people in Germany to identify the aircraft.  If we can also find nothing from the various places we look through, we will let you know.
Northern Watch
« Reply #21 on: October 05, 2011, 04:21:11 PM »
Quote
Posted by: ACW367« on: Today at 03:24:17 pm »
Keith
Hi ACW367
I will work on it today/night and post on the update tread.
Keith
tailplane
« Reply #22 on: October 16, 2011, 04:23:06 AM »
This is an analysis result of Navdata.db320110925.
Please refer to it.
http://www.ne.jp/asahi/nature/kuro/RDBX/exposition/Navdata_db3_20110925.xps
