Mlat
Started by lambertw, November 12, 2011, 09:54:45 AM
#45
Hi Jon, I just wanted to confirm, that -according to my information- you are right with your statement, that MLAT can't be realised with the existing hardware.
Further I wanted to tell that there might be a chance for MLAT based on a new hardware, because of the fact Oliver asked for anything I  the pipeline. IMO that inclues new hardware.
I hope we are "clear of conflict" now.
Hi Ingo - no conflict, just slight confusion!
lambertw
I have given up on expecting ANRB to come up with a MALT capable system, over two years now in waiting since start of this thread ,(in my opinion its never going to happen ).
oliver14
By the time they have got round to it, I reckon almost everything will be using ADS-B anyway, as I have said before, I would love an advanced " my flights " filter, using wildcards, 43C*, AE*, etc.
You can do this on the map.
Does anyone work on the development side these days ? or are all resources being used on the public domain side of things !
#49
Oliver,
I may be picking you up wrong but you can filter 43C*, AE or any other wildcard on myflights.
If there is something you would like to see on the software drop them an email.
As has been stated previously MLAT is not possible with the current hardware.
You certainly can. Click on the ´Alerts´box and you can put in wildcards under various headings .
You can filter via quick filter anything on the drop down list.
oliver14
Hi, and thanks for the replies, sorry I should have said, it was multiple filters I would like, unless I am mistaken you can only select one in my flights, e.g. 43C*  it would be good to be able to filter AE*,43C*, etc.
Is this possible now, it doesn't seem to work for me,  cheers.
Are we talking alerts or filters here?
Whether in myflights or network flights you can only filter on one thing at a time using quick filter. How are you filtering on more than one the network?
oliver14
Hi Alan, I want a quick filter to be able to read:
Mode-S  =  43C*, AE* in the my flights list, to single out US and RAF aircraft,
hope this makes sense.
#55
Understand that Oliver, how do you do it on the Network or are you talking RB24 here when you say on the map?
CYYZGUY
I have noticed a huge increase in ADS-B flights in Canada over the last 6 months.....It wont be long until all aircraft are compliant.
Europe has it way better then north america at the moment!
Jason
40" LED Monitor
40" LED Monitor
oliver14
Hi Alan, I am not on the network, and this is on the Radarbox software.
In filters, advanced filters, and on the aircraft tab you can select:
B78*, A38*, B74* etc, and this allows you to view just these aircraft on the radarbox map.
You can do this on My flights quick filter, but only for one option, e.g. B78*   it does not allow you to select multiple options, if you type in B78*,A38* all flights vanish.
#58
Thanks for the explanation Oliver, it helps to know what you mean, I didnt have a clue what you meant by being able to do it on the map.  I will add it to the requests list.
oliver14
Great, thanks Alan.
