Started by orkney, November 26, 2011, 04:40:34 PM
0 Members and 6 Guests are viewing this topic.
54901 - Jim
More O/O updates ...
A07E81 / N1307C - J A Flight Services LLC
A56856 / N448AA - Air Capital Group LLC
A6C41C / N535MJ - AR Aviation LLC
AC9452 / N91A - Jim Pattison USA Inc
A0F08B / N16NK - Wells Fargo Bank Northwest NA Trustee
AB34A3 / N821AS - US Bank NA Trustee
A4EC80 / N416XJ - US Bank NA Trustee
AD841D / N970EV - US Bank NA Trustee
AC2576 / N882CA - ConAgra Foods Inc
AA7831 / N774DC - Berkshire Building Services Inc
A51995 / N428CM - LN Air LLC
A17B5F / N195GL - Great Lakes Aviation Ltd
A830FB / N627HP - Michael Hodes
AA017C / N744AX - Cargo Aircraft Management Inc
A17FF3 / N196RG - XLS Aviation LLC
A9F657 / N741AX - Cargo Aircraft Management Inc
Thanks!
KOSH - Oshkosh, Wisconsin USA
Thanks again Jim
Please note airliners are detailed in the d/b with the Airline name and not the leasing company.  i.e. N821AS is in the d/b with the CO as ExpressJet Airlines/Delta Connection and not US Bank NA Trustee
anorak
4D02A3 / LXJFR (?) Not populating and nothing on Airframes.
Thanks,  Dave.
Dave. Exmoor, North Devon.
Evening, the unknowns from yesterday:
3C665C (Germany)
3EB9EB (Germany)
3F9F56 (Germany)
3FAD46 (Germany)
3FBA58 (Germany)
4B8750 TC-AZP B738 Boeing 737-82R Pegasus 38176/3896
4FAB46 (with GAMH flight id's)
502C85 (Latvia MTL577 flight id, still nothing on it)
867FA0 (Japan, no flight id)
894026 (Bahrain, no flight id)
That's all from yesterday.
If 4D02A3 (flight id LXJFR) is LX-JFR it would be a PC12 Pilatus PC-12/47 of Jetfly (http://www.flugzeugbilder.de/search4.cgi?srch=LX-JFR&stype=reg&srng=2)
Dave,
4D02A3, LX-JFR, Pilatus PC-12/47E, c/n 1233, Jetfly Aviation
54901 - Jim
RE: N821AS
Which resource do you use to check that info, Alan?  The FAA Registry isn't showing that.  I guess I need something more comprehensive w/ better info.  Thanks, in advance!
Jim,
Unfortunately as you state the FAA registry only details the owner not the operator.  I personally use my d/b for the operator details but I suppose that google would provide the operator details but checks need to be made that the source is up to date as regional airliners in particular can change operator/franchises.
I was only informing you in case you check following the next Navdata release and found that it hadnt been changed to what you advised so that you were aware of the reason. To save you further work I am very happy for you to pass the data you have available from the FAA and I will amend where necessary.
Thanks again for the time and effort you put in to providing these updates as they are very much appreciated.
54901 - Jim
54901 - Jim
More updates ...
AB2E0A / N8196W / P28A / Piper PA28-180 / Jeffery Grandgenett / 28-2324 (FULL RECORD)
A983B7 / N712CK - Kelsey Investments LLC
C0661E / C-GMRL - Skyservice Business Aviation Inc
A9F2A0 / N740AX - Cargo Aircraft Management Inc
Thanks!
54901 - Jim
Missing ...
A958DE / N701GC / CH70 / Zenair CH701 / David Hurst / 7-6634
Thanks!
54901 - Jim
Updates ...
A572B6 / N450GD / GLF4 / Gulfstream G450 / Gulfstream Aerospace Corp / 4225
A344B3 / N31CJ - BKD LLP
Thanks!
54901 - Jim
Another batch ...
A8163D / N620A - Threshold Ventures Inc
A9D7D5 / N733SW - Butler National Inc
AC1F82 / N880TD - Employers Benefit Group LLC
AB8318 / N8406W - William Howlett
ACAE3B / N916PA - Todd Agency Inc
A3E553 / N350FJ - Ronald Piercy
ACCD21 / N924BB - Fins and Feathers LLC
Thanks!
X
#1034
I know you know D-AIDO and G-EUYN but they are not populating but G-EUYN also pinged with an easyJet f/n!!!!
Mode S  Flight   Route           Regist  Airc  Airline              Date and Time
* 3B773F                                                              2012/01/26 12:08:40
* 3C648F  DLH3H    EGLL-EDDF  D-AIDO                 2012/01/26 11:49:41
* 3C648F  DLH7FT   EDDF-EGLL  D-AIDO                 2012/01/26 10:10:50
* 400BF1                                                              2012/01/26 11:54:25
   406674  BAW816   LEMD-EGKK  G-EUYN                     2012/01/26 12:26:29
   406674  EZY5476  LEMD-EGKK                                   2012/01/26 12:26:15
* 43C4C7  ZD984                                                       2012/01/26 12:30:54
* 75826B  RPC8191                                                     2012/01/26 11:18:48
* 760010                                                              2012/01/26 11:21:48
* AE2407                                                              2012/01/26 11:11:48
X at the Row
