Started by orkney, November 26, 2011, 04:40:34 PM
ACW367
#1065
Quote from: 54901 - Jim on January 27, 2012, 06:01:02 PM
More updates ...
A25C54 / N251MM - Beauty Central LLC
AAC6F7 / N794AX - Cargo Aircraft Management Inc
Thanks!
Jim
To show the level of sleuthing required
These aircraft are as you say registered to the entities as you show.
On the RVSM list N251MM shows as follows:
White Cloud Company GLF4 1495 N251MM TRUE 11/28/2011
Googling 'White Cloud Gulfstream'  came up with the following
http://www.whitecloudcharter.com/fleet.php?page=iv
Therefore the best presentation is:  White Cloud Charter/Beauty Central
For N794AX CH Aviation give the following:
ABX Air
Hub: Wilmington, OH | IATA: GB | ICAO: ABX | details
C/N MSN last update model registration remarks
115 23144  B767-281(PC) N794AX Stored at Tel Aviv (TLV) / to be converted
Cargo Aircraft Management are one of the companies in the group that owns ATI and ABX Air.  Therefore if you are picking it up in the USA it appears to have been delivered to ABX Air following freighter conversion.
54901 - Jim
Thanks again! Always happy to learn something new!
KOSH - Oshkosh, Wisconsin USA
flygfantast
Quote from: flygfantast on January 27, 2012, 04:23:25 PM
Not populating: 4787AC, LN-IDC
Found the following on LAAS:
LN-IDC   Cessna 560 Citation Encore   560-0652   reservation (ex YR-ELV)
Niklas
Cable: Ecoflex-10 (10m+1m)
Hallo! One from today:
3D13BF D-EFSP C172 Cessna 172 SP Sportflieger Club Porta- Westfalica e.V. CN:? (Mk1EB: http://www.scp-porta.de/unsere_flugzeuge.htm )
chewycanes
Afternoon Alan
484CA7 PH-PED TBM8 C.J.M.BERTENS (from AF & GA)
Brian
Hi Brian
PH-PED c/n 537 has also been assigned N97RN since last October, hex AD82D0 although I dont know if it has taken it up yet.
Good Morning! The unknowns from Friday:
001BB6 (no country allocation, so a miscoded airframe or a decoding error)
395008 (France)
3C674C (Germany)
44060E OE-GTH (is already in the db by now)
760920 (Pakistan)
That's all from Friday
The unknowns from yesterday:
01804F (Libya with flight id: HB_GHV)
2E2703 (No country allocation, so miscoded airframe or a decoding error)
3C664A a 100% decoding error of 3C664E, determined be flight id, receiving time, message count and position data)
3FAA8C 85+12 H53 VFW-Fokker CH-53G (S-65) German Army V65-110 (airframes)
48403A (Netherlands, it was PH-BDU a B734 until 2009)
That's all from yesterday.
One from today morning:
4403A5 OE-INN CL60 Bombardier CL-600-2B16 Challenger 605 VistaJet 5743 (airframe, latest Mk1EB from September 28th 2011: http://www.flugzeugbilder.de/show.php?id=1093325 )
Morning Ingo
Fridays
001BB6 unknown to me
395008 decodes to F-GUAI unknown
3C674C decodes to D-AIZL UNKNOWN
44060E OE-GTH, Beech B300 King Air 350, c/n FL-702
760920 unknown to me
Saturdays
01804F 5A-DHV, Beech 300 Super King Air, c/n FA-170, Libyan Air Ambulance, ex HB-GHV
2E2703 uknown to me
48403A decodes to PH-BDU which is now 5A-MAB, Boeing 737-406, c/n 24857/1902, Buraq Air
Today
OE-INN c/n 5743 is now assigned N291KR by FAA and was removed from d/b.  As tranfer would not appear to have yet taken place, OE-INN has now been returned to d/b
X
lots of ground stuff at Gatwick 43B*** and two unknowns that have not populated
* 343380                                                              2012/01/29 18:35:04
* 43BF18        2012/01/29 15:07:52
* 43BF18        2012/01/29 19:55:31
* 43BF37  POEMSAA2                                                   2012/01/29 15:02:50
* 43BF37  POEMSAA2                                                   2012/01/29 16:50:04
* 43BF37  POEMSBB1                                                   2012/01/29 16:49:52
* 43BFE9  TELS 1                                                         2012/01/29 16:28:27
* 43BFEB  LEADER 2                                                    2012/01/29 19:51:47
* 43BFEC  LEADER 3                                                    2012/01/29 15:50:15
* 43BFF0  LEADER 5                                                    2012/01/29 16:17:44
* 4CA831        2012/01/29 17:43:15
X at LGW
X
N502P G550 was seen at Luton 23/1/12 and not in DB
X
