Started by orkney, November 26, 2011, 04:40:34 PM
X
#1426
X
601096 EX-37501, ex UR-AAM, can you advise the operator?
8960F6 A6-EDU, Airbus A380-861, c/n 98, Emirates
E034C3 LV-CSC, Boeing 737-7Q8, 30630/1032, Aerolineas Argentinas
Thanks Niklas amendments made.
chewycanes
#1428
Morning Alan
My apologies. I need to goto specsavers....
It was
885043 THA8465 HS-TBC A333 Thai Airways (from GA) and not 894043 as i stated.
Brian
Edit This has now populated.
X
Nothing available on S5-PEB yet, it appears to jave been first noted in January however.
Morning Ingo,
3E8385 unknown
400F9E decodes to EC30 G-CEDH which became HB-ZJH and which in turn has now been cancelled from the Swiss register as exported
8960F6 A6-EDU, Airbus a380-861, c/n 98, Emirates on delivery
X
#1431
Quote from: Runway 31 on February 25, 2012, 09:08:28 AM
X
I have it as below, and UR-AAM is on approach to Moscow as I write
EX-73501   B737-59D   26419/2186 Kyrghz Airlines    ex SE-DNI, G-OBMY, OY-SEG, LY-BFV, G-GFFD
X
X
#1432
There seems to be is a lot of confusion on the net on UR-AAM and which one it is (either 26419 or 24919)
I have this
UR-AAM B735 Boeing 737-548W/L 24919/1970 ex EI-BXF, EI-CDB, YL-BBG, UP-B3708
X
X
000158 just went OTT me at 6000 and is a C130 not a P3!
X
#1434
Thanks X
The details you gave for both aircraft are as I have them.  I presume I must have made a mistake when looking up, thanks for the clarification
Just traced my steps, instead of using the d/b I googled and found a link to the registration EX-73501 but when clicked it gives the details for UR-AAM
Nothing on the C130
Bob SEN
Afternoon Alan
some news from SEN
"Scrapping commenced of B462 GTBIC outside the Trygon hangar on 15/2,and
by 25/2 the final rear section of the fuselage(with the reg) and a pile
of scrap metal was all that remained.
Ex Armavia A320 MABEM is to be dismantled here,and was noted 25/2 as
work underway outside ATC hangar bay 5."
Courtesy of Kev
Bob
1/2 a mile South of EGMC/SEN
Afternoon, a major Database amendment do proceed:
The Bundesgrenzschutz was renamed to Bundespolizei in July 2005. Therefore all Helicopters with operator Bundesgrenzschutz shall be renamed to Bundespolizei:
3E0A41   D-HVBT   EC35   Eurocopter EC135 T2   Bundesgenzschutz (still valid)
3E0A42   D-HVBU   EC35   Eurocopter EC135 T2   Bundesgenzschutz (still valid)
3E0A32   D-HVBE   EC35   Eurocopter EC135 T1   Bundesgenzschutz (still valid)
3E0A30   D-HVBC   EC35   Eurocopter EC135 T2+   Bundesgenzschutz (still valid)
3E0A35   D-HVBH   EC35   Eurocopter EC135 T1   Bundesgrenzchutz (still valid)
3DDDCD   D-HEGB   AS32   Eurocopter AS332 L1 Super Puma   Bundesgrenzschitz (still valid)
3E0A3E   D-HVBQ   EC35   Eurocopter EC135 T2+   Bundesgrenzschutes (still valid)
3E0A40   D-HVBS   EC35   Eurocopter EC135 T2   Bundesgrenzschutz (still valid)
3E0A37   D-HVBJ   EC35   Eurocopter EC135 T1   Bundesgrenzschutz (still valid)
3DF1A3   D-HLTJ   EC55   Eurocopter EC155 B     Bundesgrenzschutz (might be no longer valid)
3DF1A6   D-HLTM   EC55   Eurocopter EC155 B    Bundesgrenzschutz (still valid)
3E0A3F   D-HVBR   EC35   Eurocopter EC135 T2   Bundesgrenzschutz (still valid)
3DF1A5   D-HLTL   EC55   Eurocopter EC155 B    Bundesgrenzschutz (still valid)
3E0A3B   D-HVBN   EC35   Eurocopter EC135 T2+   Bundesgrenzschutz (still valid)
3DDDCE   D-HEGC   AS32   Eurocopter AS332 L1 Super Puma   Bundesgrenzschutz (still valid)
3DF19A   D-HLTA   EC55   Eurocopter EC155 B           Bundesgrenzschutz (still valid)
3DF19F   D-HLTF   EC55   Eurocopter EC155 B           Bundesgrenzschutz (still valid)
3DF1A1   D-HLTH   EC55   Eurocopter EC155 B     Bundesgrenzschutz (still valid)
3DF1A2   D-HLTI   EC55   Eurocopter EC155 B    Bundesgrenzschutz (still valid)
3DF1A4   D-HLTK   EC55   Eurocopter EC155 B    Bundesgrenzschutz (still valid)
3E0A39   D-HVBL   EC35   Eurocopter EC135 T2   Bundesgrenzschutz (still valid)
3DE955   D-HIPP   B212   Bell 212                        Bundesgrenzschutz (still valid)
3E0A33   D-HVBF   EC35   Eurocopter EC135 T1   Bundesgrenzschutz (still valid)
3DF19D   D-HLTD   EC55   Eurocopter EC155 B           Bundesgrenzschutz (still valid)
3DE6B1   D-HHPP   B212   Bell 212                           Bundesgrenzschutz (still valid)
3DF19C   D-HLTC   EC55   Eurocopter EC155 B    Bundesgrenzschutz (still valid)
3E0A3C   D-HVBO   EC35   Eurocopter EC135 T2+   Bundesgrenzschutz (still valid)
3E0A3A   D-HVBM   EC35   Eurocopter EC135 T2   Bundesgrenzschutz (still valid)
3DE40D   D-HGPP   B212   Bell 212                          Bundesgrenzschutz (still valid)
3E0A34   D-HVBG   EC35   Eurocopter EC135 T1   Bundesgrenzschutz (still valid)
3E0A43   D-HVBV   EC35   Eurocopter EC135 T2   Bundesgrenzshutz (still valid)
3DDDCC   D-HEGA   AS32   Eurocopter AS332 L1 Super Puma   Bundesgrenzshutz (still valid)
3DF1A0   D-HLTG   EC55   Eurocopter EC155 B    Bundesgrenzshutz (still valid)
(still valid) short check, if the hex, registration combination was used/sighted in the past 12 month. If you have some spare time you may consider checking the AN too. According to http://bos-fahrzeuge.info some of the helicopters have got an upgrade (T2 to T2+ e.g.).
The Following Helicopters having typos in Cell Operator:
3DDDE2   D-HEGW   AS32   Eurocopter AS332 L1 Super Puma   Bundespolezei
3E0A38   D-HVBK   EC35   Eurocopter EC135 T2+   Bundespolezei
3E1681   D-HZSJ   EC35   Eurocopter EC135 T2+   Bundespolitzei
3E02E1   D-HSHD   EC20   Eurocopter EC120 B Colibri   Bundespolitzei
3E02DF   D-HSHB   EC20   Eurocopter EC120 B Colibri   Bundespolitzei
3E1680   D-HZSI   EC35   Eurocopter EC135 T2+   Bundespolitzei
3DDDD7   D-HEGL   AS32   Eurocopter AS332 L1 Super Puma   Bundespolitzei
3E0A46   D-HVBY   EC35   Eurocopter EC135 T2   Bundespolitzei
3E1682   D-HZSK   EC35   Eurocopter EC135 T2+   Bundespolitzei
3E1683   D-HZSL   EC35   Eurocopter EC135 T2+   Bundespolitzi
3DDDDA   D-HEGO   AS32   Eurocopter AS332 L2 Super Puma   Bundespolzei   2050
3DDDDB   D-HEGP   AS32   Eurocopter AS332 L1 Super Puma   Bundespolzei   2115
All shall be amended to Operator Bundespolizei (<- Copy and paste)
3E0A44   D-HVBW   EC35   Eurocopter EC135 T2+   Bundespolizei.   0342  (Just remove the '.')
Thanks Ingo, much appreciated, amended
