Started by orkney, November 26, 2011, 04:40:34 PM
X
#165
60005F eyeballed locally as EK76485 IL76...one down a few to go.
60006C therefore is probably EK76425 IL76 as suggested before but needs confirmation.
Some local miscodes matched up
000001 DU-141 AgustaWestland AW139 c/n 31224 Dubai Air Wing (but also used by a C2A c/s RG01)
000896 DU-140 AgustaWestland AW139 c/n 31073 Dubai Air Wing
DU-139 AgustaWestland AW.139 c/n 31029 seen in Inverness, Scotland recently so more likely you can find out than me!
X
Thanks X
Nothing heard by me regarding DU-139
X
#167
Another change required
DUSD-444 DHC6 Sky Dive Dubai now photographed today wearing new registration DU-SD4 (still miscoding 3928EC)
Believe it did the drop over Dubai 7's last night
PS Still suffering from consuming far too much yesterday!
X
ACW367
#168
DU-139 is one of the many users of Hex 000000, pick it up regularly and saw him fly past my house with this code on 4 Nov.
Morning, the list of Saturday unknowns:
3C48A0 (Germany)
4401A3 This once was OE-FGL a C25A of Alpla Air Charter, but this one was re-registered.
A2BB06 (would match to N275WC)
That's all.
Morning Ingo,
3C48A0 unknown to me
4401A3 OE-FGL is now G-CGSB of Air Charter Scotland
A2BB06 N275WC, Boeing 727-277, c/n 20549/989 which my d/b is showing as broken up and is showing on the FAA website with an expired certificate.
Thanks X
Sorry no sympathy for self inflicted wounds!!
Ingo,
Following your query on DG80, ACW did some digging and we have standardised this code as below
The Type certificate is here. http://www.easa.europa.eu/certification/type-certificates/docs/aircrafts/EASA-TCDS-A.067_DG_Flugzeugbau_DG--800-04-02112010.pdf
Again this is one where the company website gives differences in spacing from the TCDS.  We will go with the TCDS. The TCDS gives a space between the model number.
The DG-808 is shown on the TCDS as:
a) Type:     DG-800
b) Variant:  DG-808
Therefore happy they are included in the DG80 ICAO code
The DG-808 C comes in two further sub-variants detailed on the TCDS: Competition or Classic
Glaser-Dirks folded in 1996, DG Flugzeugbau formed that year, so that gives following:
Motor-Glider ICAO DG80:
Glaser-Dirks DG-800 A
DG Flugzeugbau DG-800 A
Glaser-Dirks DG-800 B
DG Flugzeugbau DG-800 B
DG Flugzeugbau DG-808 C Competition
DG Flugzeugbau DG-808 C Classic
Glaser-Dirks DG-800 LA
DG Flugzeugbau DG-800 LA
Sailplane ICAO GLID:
Glaser-Dirks DG-800 S
DG Flugzeugbau DG-800 S
DG Flugzeugbau DG-808 S
X
Quote from: ACW367 on December 04, 2011, 12:24:13 AM
ACW367
Thanks, the Sheikh on his way to races no doubt!
000000 also noted recently on UAE 2011 AW139 but used by various others including another US Navy C2A
X
Alan, ACW
many thanks for the research efforts you have put into my DG80 request. I'm looking forward to participate from this efforts within the next database update release. Or, if I find some spare time, a little earlier by performing a manual database update. Thanks Again.
X
#175
Not sure if this was me or you, but DU-142 has just populated as a A319 should be A139.
PS confirmed by photo 26/11/11 as wearing DU-142 as previously advised!!
X
X
The d/b has it as an A139, amended 1/12 at 16:29 after release on latest Navdata, please update manually until next Navdata release
X
A question, at what time/date was the new db updated until, as VT-LTA I advised 29/11 does not appear.
quote "Arrived in sandpit  8005E0 VT-LTA H25B Hawker 900XP c/n HA-0165"
X
X
VT-LTA added 29/11/2011 19:19:20 and as advised on my reply at 1906 on that date I had been away from the computer all afternoon for reasons known to yourself
X
VT-LTA operator is apparently M/s L & T Aviation Services PVT Limited (assume L & T Aviation Services for db) registered 21.10.2010.
X
