Started by orkney, November 26, 2011, 04:40:34 PM
0 Members and 6 Guests are viewing this topic.
Blueboy
Hi Alan, picking up A55A93 with flight ID N444MG. This appears to be a Hawker 800XP  c/n 258415  of WFBN
J.D
Blueboy
Hi Alan, another one I've just picked up 3853DB with Flight ID AIB24KG - this one is tracking at FL410
J.D
JD
Correct with N444MG
3853DB F-WJKG, A340-600CJ c/n 924 for Jordanian Government as per mode-s forum
Northern Watch
QuotePosted by: Blueboy
« on: Today at 11:05:12 am » Insert Quote
J.D
Also been tracking it and FR24 has it as F-WJKG / A340-642X / Airbus Test Registration
Keith
X
8A0230 unknown to me
780832 B-6850, Airbus A320-214, c/n 4347, Chengdu Airlines
F-WJKG will become JY-ASX when delivered.
Chris,
Changed 00A4AB to ZS-PZU let me know when ZS-NWK start coding.  Unfortunatly when we pick up a code we assume that the code relates to the allocation until we are advised otherwise.
Paul,
Noted on the mode-s forum that although A4CCE0 is as you state N4081M it is being used by EC-LNZ Cessna 510 Citation Mustang c/n 510-0368 still using its delivery hex.  Inbound Manchester this time.
Chris11
3C544B D-AEBK  Embraer ERJ-195LR (ERJ-190-200 LR)  19000500 Lufthansa CityLine
Thanks Chris,
Added at 1311 as it approached the south west coast of Spain.
flygfantast
Not populating A72E95 N562CL
Niklas
Cable: Ecoflex-10 (10m+1m)
Hi Niklas,
A72E95 decodes to N562CL as you detail, nothing on the FAA website this time other than a note detailing the registration is reserved for a company called N-Jet on 8/11/2011.
X
John Hargreaves
X
478760  LN-NOY  B737-8JP  c/n 39419/3878  Norwegian Air Shuttle
Also around Seattle at the same time was -
4CA9C2  EI-EVB  B737-8AS  c/n 34982/3886  Ryanair
John H.
