Belkin Network USB Hub
Started by tarbat, January 27, 2012, 11:23:31 AM
frogger
OK, thanks.
If it is ok, i would by a SX-3000 too to get my radarbox to the loft.
Okay, after 5 days constant running both Radarbox and ShipTrax have remained connected without any problems.  A total of 2,273,139 ModeS messages recorded, and 94,349 AIS messages recorded.
Looks reliable to me.
frogger
Thank you Tarbat.
That looks good. I will now buy a silex 3000gb and get the radar box up to the loft.
anorak
I now have the Silex SX-3000GB working on my laptop, running now for over 1 1/2hrs,. I would like to thank Tarbat for his patience in helping me get it working.
Dave.
Dave. Exmoor, North Devon.
frogger
Short Report after 3 weeks of using the silex-box:
It works great. No faults or errors in my virtual machine. Thanks for helping!
Aerotower
Hi guys!
Any reported problem?
And it is possible use the silex over internet?
Thanks,
anorak
I must say that the Silex  product has work faultlessly, I have also changed my protection software to ESET and found the set up to start and run quicker.
Thanks again to The Big " T "    Dave.
Same here.  I always run my ShipTrax and Radarbox through the Silex, it's enabled me to locate the hardware receivers remote from my PC location, connected over wireless using a Netgear Ethernet to wireless adaptor. Works flawlessly.
Aerotower
And if we're away from home you can access selix if he's at home?
And have access to RadarBox?
How do you guys do?
#24
Quote from: Aerotower on December 15, 2012, 11:26:42 PMAnd it is possible use the silex over internet?
I've never tried.  I guess it would depend on what bandwidth you have available on the Internet, and how the PC would "discover" the Silex.  I don't think it's really designed to work over the Internet.
juangelb35
Hummmmmm,
Is it possible to configure an gateway IP on it ???
If not .... You will need some workarounds ... like configure VPN on both sides.....
Since 5 years  using two Uboxes from Lantronix .... Withdrawn since a long time ago....
But this device allows to do this ... not working on W7 64 bits... no 64 bits device drivers at allll,
But still working ok in W7 32 using an Ubox OEM software ... Keypan ....
One Ubox was left alone at remote location since 4 years now ... along with a RadarBox...
All working well till today ... never powered off nor disconnected antenna , etcs... no matter what the weather is.... Bolts, thunders ... no matter ...
Cheers - juan
Aerotower
Thank you both.
Juan can you send some links with this informations?
Tarbat you can try?
knight01
I'm thinking of getting the Silex SX3000GB. How is it performing with the radarbox and does it send data over wifi via the router?
Yes, if you use it with a wireless adaptor.  I use a Netgear Ethernet to Wirless Adaptor, powered by the Silex.
