New Navdata.db3 - 20120129
Started by AirNav Development, January 29, 2012, 10:08:34 AM
lebelgepatte
oke thx alan
only problem is that i have some aircraft without a silhouetts
is that normal?
Which aircraft are without a silhouette, these may be ones that are not available.  Its nothing to do with the update.  If you advise which ones you require someone may be able to assist.
lebelgepatte
#17
before i didn't have this problem
know i can't see any militairy aircraft sillhouette
and little plane's like a-300s cessna, ...
canadair, embrear 190 .....
I cant imgine why this would be, lebelgepatte.  Are  the aircraft in the silhouettes folder?  Which version of radarbox are you using?
lebelgepatte
hi, all aircraft are in the folder  and the version 4.03 with last update from on the forum
I am at a loss to explain why silhouettes suddenly dont appear, anyone able to give a clue?
#21
lebelgepatte,
Just a hunch, from database explorer, how many aircraft are in your database?  Do you have a previous version of radarbox on your computer as you may have updated the wrong version if you failed to delete the original version when ypou upgraded to 4.03
lebelgepatte
#22
at this moment i have only 600 in database  just before i had to reinstall everything i had almost 11.000
i bought de radarbox 3d in september 2011
the CD is version is 4.03
i have a lot of aircraft with this [...]
raytheon hawker 750
embraer 190-200lr
havilland canada dhc 8 q402
canadair cl 600 2d24
saab 340 af
dassault falcon 7x
Lebellgepatte, you should have around about 136,000 aircraft in your database having updated with this latest Navdata.
Please run the navdata again, close down radarbox before you do.  Run the navdata and have it install to where you have version 4.03 installed to. When it is finished restart radarbox and let me know how it has went
lebelgepatte
runway 31
i have deinstall everything
i just installed airnavradar again and just update with this version  but still i have the same aircraft without a sillhouette
Do you have some 136,000 aircraft in database explorer?
Top left of main screen/File/Database explorer, click on this.  It will bring up a box in the centre of the screen, top line change to aircraft in drop down box.  Once changed look at bottom left corner it should state ********** rows on **ms
lebelgepatte
136.148 rows loaded
i reinstall everything and did the update
i think that everything is fine at this moment
the only one i don't have is the airbus a380-861 but that it's normal
i will keep you up to date if i have the same problem
Good, looks like you need the A388 Silhouette so I have attached it, save in your silhouette folder and it should display next time you start up and see A380 aircraft
SAlan
