Author Topic: Format output port 30003  (Read 16247 times)
Re: Format output port 30003
« Reply #15 on: July 26, 2010, 06:44:48 AM »
Tony, a lot has happened since this thread.  Whay "status" do you want, on a thread over 18 months old?
« Reply #16 on: July 26, 2010, 06:54:24 AM »
bumping this to see what the current status is ...  It's relevant to my recent request of trying to 'get at' the Myflights data so I can integrate with my Aircraft tracking database.
What MSGs are you referring to ?  Apart from the absence of MSG 8 (which I agree is a PITA), you should see all the other Kinetic MSG formats in the socket output with the latest RB release (apart from MSG 7, which is a red herring as neither RB nor SBS decode the relevant DF).
If you need DF11s (MSG 8) you might be better off pursuing the option mentioned in this thread:
www.airnavsystems.com/forum/index.php?topic=5264.0
where we're told that RadarBox can offer the ability to get at raw ICAO data (which would give you everything you need).
Having said that, no details of how to do this have so far been forthcoming.
« Reply #17 on: July 26, 2010, 07:37:44 AM »
Just some confusion from the other post Dave, he had contacted us via support before the forum post and he wanted Asterix format and was a bit confused in how to describe it.
This is not posssible at the moment.
« Reply #18 on: July 26, 2010, 07:40:55 AM »
Okay, if Asterix format is the requirement, then perhaps he should buy an SBS-2, which has an ASTERIX CAT 21 data stream.
