Populate error
Started by Marinus, March 25, 2008, 11:41:03 AM
It's going to be a nightmare to clean up the polluted data in the aicraft table :(
Quote from: tarbat on March 25, 2008, 04:29:32 PM
You must be able to come up with an SQL query that can tell the difference between numbers and letters - is there an ascii type filter?
Do that a couple of times, export, import etc - piece of cake :-0
Except for the companies that start with numbers, and the serial numbers that start with letters - agghhhhhhh..........
Maybe I'll just leave it as it is!
Roadrunner
Could try doing them manually - that is if you have a year or so spare ? ? ? :-(
EINN-07
My first corrupted record dates to March 7th !
Quote from: EINN-07 on March 25, 2008, 08:21:30 PM
You mean that this was the first time that you detected that aircraft?  But was it already in the NavData.db3 database?  MyLog is populated from NavData if the record is present, then from Autopopulate if it isn't. so the date doesn't necessarily mean a great deal.
EINN-07
True,
The date of first detection was March 7th but I could count on the fingers of one hand the number of times I have populated in the past three weeks and would be pretty certain that the dates match ie the date the data was downloaded was March 7th
Marinus
Hello Airnav,
Any progress regarding this bug ?? as I'm still getting
these and my Database get's more and more corrupted,
alsmost impossible now to correct things manually....
Marinus.
It should be fixed for 1.6. Its not a easy to bug to rectify.
Marinus
Ok,
Roger that..... thanks for the swift reply regarding my question
Marinus.
