Started by orkney, April 06, 2012, 10:35:27 AM
diddyboy
Hi Alan
An amendment for you.
07C022 is not ST-ATA A300-B4-622R, but is ST-PAW An-32B c/no 3209 Sudanese Police Air Wing. Confirmed today at Khartoum.
Hi Neil,
All the d/b's GAS, Airframes etc give 07C022 as ST-ATA.  Can you advise what it is using if that is the case, do we have two aircraft using this hex?
diddyboy
Hi Alan
As far as I am aware ST-ATA is currently stored at Khartoum and hasn't moved from the Sudan Airways Hanger for sometime. The only A300 that I have seen flying for a while is ST-ATB.
Neil
X
#304
 Alan/Neil
07C022 ST-ATA A300 was a regular here till end 2010, not seen since. An32 ST-PAW not seen in sandpit so a box swop or is the A306 pinging while on ground tests?
   07C022  SUD232   HSSS-OMDB       ST-ATA  A306  Sudan Airways        2010/12/31 18:23:56
   07C022  SUD233                            ST-ATA  A306  Sudan Airways        2010/12/31 20:24:03
X
X
Time will tell but I wil go with Neil at this time
Judwin45
B623C2 is an AW-101 Mk.641  c/n 50242 flying today out of Westlands.
Keith
5 miles south of EGDY
c/n 50242 is ZR338 which is for the Indian Navy
54901 - Jim
Hello, Alan! Some updates for you ...
A176A7 / N1937K - Griffin Contracting Co
A0A05F / N14AH - 4AH LLC
A01761 / N105BA - Bill Austin Aircraft & Yacht Sales
A09C62 / N1388J - Landes Valenta 2012 LLC
A0F331 / N160RM - TJ Air Holdings Inc Trustee
A0C9FB / N15XZ - Wells Fargo Bank Northwest NA Trustee
A13E93 / N18CP - Powerplay Powerboats Inc
A0D177 / N15188 / ???? / Pool-Cessna / Fletcher Pool / T-41BT
Thanks!
KOSH - Oshkosh, Wisconsin USA
FACTflights
Thanks Alan,  will get to know as we go along.
John
ZS1AGH
No HF antennae at the moment.
Evening, the unknowns from Wednesday:
39A70F (France, no flight id)
3C48F9 (Germany, no flight id)
3C5960 (Germany, no flight id, still no further info)
3D1F00 (Germany, flight id: DEKHZ, so decoding error of D-EKHZ 3D1FDF)
3D22F9 (Germany, flight id: DELMN, no further info)
3DD3E4 (Germany, flight id: DHAMM, D-HAMM B06 Agusta-Bell AB206B Agrarflug Helilift GmbH 8692 source: http://www.helionline.de/?news=YToxOntzOjQ6InBhZ2UiO2Q6MTY7fQ== )
3FBCFA (Germany, no flight id)
4005C4 (UK, flight id: AM_ _ _ED, no active one found)
44CDC6 (Belgium, flight id: BEL3NY, decoding error of 44CDC2)
45AD03 (Denmark, no flight id, no active one found)
45B2AB (Denmark, no flight id)
48051B (Netherlands, no flight id, no further info)
999999 (no allocation, no flight id, miscode)
DE0E00 (no allocation, flight id: DEZXA, a heavy decoding error or a miscoded airframe)
E48B65 (Brazil, flight id: TAM9394, TAM: TAM Linhas Aereas, a new one on delivery?)
MIL List:
1F69A7  BLACK1
35AB28  GAMC12
35AB28  GAMC17
3E9542  ZAPATA1
3EA795  GAF128   LPLA-EDDK
3EBEED  ZAPATA2
3F5749  SNAKE1
3F58F5
3FA346  GAF782
That's all from yesterday.
RNAGG
Yes, new aircraft with register PR-MYP Airbus A320-214 CN 5066
Quote from: RNAGG on April 26, 2012, 05:13:29 PM
Was added to the d/b at 19:02 shortly after take off
Evening Ingo,
39A70F (decodes to F-HJXP, unknown to me
3C48F9 decodes to D-ABGY unknown to me
3C5960 still no further info
3D22F9 D-ELMN, Piper PA-28-181 Archer II, c/n 28-7890456
3FBCFA presumably a tac code
4005C4 decodes to G-BVYS now B462, HB-IXT
45AD03 decodes to OY-KHC, now in the US as N427NV with Allegiant
45B2AB decodes to OY-LUK, unknown to me
48051B unknown to me
DE0E00 unknown to me
3FA346, 70+70, Bell UH-1D Iroquois, c/n 8130, Germany - Army
