Started by orkney, April 06, 2012, 10:35:27 AM
paul tricker
Currently over Holland is THY7KZ, using Swiss Mode S of 4B2849
Inbound Manchester so true id should be known soon
Also
Over Brasil is E401BB  as f/n 1905482 which is E190-0548 due for China Southern, but I cannot find its PT- reg
Paul
Paul,
Discussions on the mode_s forum shows 4B2849 to be TC-JBI miscoding on the inbound leg, it used the correct 4BA849 going back out
E401BB decodes to PT-TUV
flymee1939
#902
Runway 31 Alan can you advise me, I cant get 3D or Maps or Slit screen, do I need new data?
Flymee1939 please
Done update but sorted problem by tools /interface, needed to revert back from a situation where I have since taken two of my Multiscreens out for an exhibition and forgot to correct the interface.
Bring back all is forgiven!
Flymee,
Was the internet on when you started Radarbox, if not close down Radarbox and re-start it and see what happens
RobertMB
Quote from: Xon on May 28, 2012, 04:59:43 PM
Quote from: Runway 31 on May 28, 2012, 04:50:26 PM
Got the Wizz but cannot find anything on the PC12
It's first PC12 with fuselage from PZL Świdnik. http://www.jbi.com.pl/aktualnosc/20-pilatus-pc-12-z-pierwszym-kadlubem-wyprodukowanym-w-fabryce-pzl-swidnik-sprzedany-w-polsce
48B12C SPMKM    .NO-REG       FL250  000� G000 II-09  [reg] at 12-05-28 16:14:54 UTC
Edit: URL correction
48B12C SPMKM > SP-MKM Pilatus PC-12/47E c/n 1338 ex HB-FSP
BR,
Robert
YXUphoto
A0ACEF   N1423R
A0EF25   N1598Y
A56D80   N449QX   callsign N449QX   DH8D
AA1922   N75QV
Morning, the unknowns from Monday:
34A54F (Spain, no flight id, nothing more)
3C6300 (Germany, flight id: BER780, so decoding error of 3C6304 or 3C6305)
3FF106 (Germany, flight id: DMSSQ, D-MSSQ Evektor-Aerotechnik EV97 Eurostar Private CN:? Mk1EB May 2012: http://www.planespotters.net/Aviation_Photos/photo.show?id=283101 )
406095 (UK, no flight id, airframes: G-CFZE but this one is now VH-ZFD)
463003 (Finland, no flight id, nothing more)
471EA3 (Hungary, flight id WZZ116, decoding error of 471EAB)
471F43 (Hungary, no flight id, 471F4B is in my list at nearly the same time. So it's possibly again a decoding error of this airframe.)
4843F6 (Netherlands, flight id KLM810, decoding error of 4843F2)
49134F (Portugal, flight id: NJE3NL, decoding error of 49124F)
4B2849 (Austria, flight id: THY7KZ, miscoded airframe TC-JBI)
4BA8DD (Turkey, no flight id, nothing more)
MIL List:
3EA614  GAF674
3EA6A7  GAF123
3EA6A7  GAF626   EDDL-LIRF
3EB9E4  GAF662   EDDT-EGLL
3EB9E4  GAF777
3F475B  BOMBER
3F4802  GAF910
3F7452
3F8681
3F8681  GAF063
3F879D  GAF121
3F88B8  GAF611
3F88B8  TA69
3F8AC5  LK01A
3F92E6  GAF973
3FA176  GAF124
3FAE82  TA12T
3FB825  GAF699
3FB825  GAF699
That's all for Monday. Have a nice Day!
#908
Mark,
A0ACEF   N1423R, not assigned by FAA, 2 previous both AA-1 cancelled due substantially damage
A0EF25   N1598Y, not assigned by FAA and nothing previous found
A56D80   N449QX, De Havilland Canada DHC-8-Q402 Dash 8, c/n 4410, Alaska Horizon
AA1922   N75QV, not assigned by FAA and nothing previous found
Hi Ingo,
34A54F nothing known
406095 G-CFZE now VH-ZFD EC25 c/n 2724, Bristows South East Asia
463003 OH-SET, Beech C90B King Air, c/n LJ-1360, Scanwings
471F43 nothing known so possibly as you state
4B2849 as per previous reply above to Paul
4BA8DD unknown to me
Blueboy
Hi Alan, picking up HEX 0D064E at FL240 - no other information
J.D
flymee1939
Yes internet was on, if you look at my post I edited you will see I forgot to alter the interface from a previous change. Now all is brilliant as usual. I now have multiscreen as I use flight sim too.
Ray. Thankyou for your usual prompt reply.
JD,
All that is known for this time for 0D064E is that it is a C27J on delivery to the Mexican Air Force.  c/n 4142 is due on delivery to them but its serial is unknown at this time
shouriken
#913
A87071 N643AS AerSale MD90-30 c/n 53497/2219 (ex HZ-APG) (from FAA, the mode_s list and skyliner.de) now on LRBS.
Liviu
Liviu
A.net JetPhotos.Net
RadarBox
Thanks Liviu,
Added 12:14 following the notification received from the mode-s forum but probably not updating as the network was down
