Beta testing feedback
Started by tarbat, June 04, 2012, 08:46:41 AM
Just realised that you can change aircraft when using the Pilot View - just mouse over another aircraft to change to a view from that aircraft - nice!
#16
With ASDI data turned on, I get "undefined" in a number of the Flight view fields - Model, Photo copyright.
And with >6000 aircraft on screen, performance really suffers, with >700MB of memory in use, but being able to display ASDI data is a real bonus feature!!
Yes a real performance hit but its amazing to see so many aircraft, even  if there is not as much detail on the ASDI aircraft as on the ones provided by Radarbox.
AirNav 3D Development
I will get the flight data updated in the left column for ASDI very soon. We just need to combine a couple of databases together first to make it work. Hopefully in the next day or so.
Also, there are some duplicates when ASDI is enabled (an ADS-B RB copy and an ASDI copy). We're working on removing the ASDI duplicate if applicable.
Any suggestions regarding how best to show ASDI flights? I'm currently using a green icon -- does that seem ok? Any other color suggestions?
There is also some ASDI trails that get 'spiked' for some reason. I'm working to try to filter out the 'spikes'.
Green is OK for me, stands out well against the background.
Quote from: Runway 31 on June 13, 2012, 06:54:25 AM
Agreed.
Can't access the new URL at present.  On opening the page I get:
Token is Invalid or Expired
Entering user name and password I get:
Login Error
Invalid Credentials
Working okay here (in Chrome).  Maybe a cached data problem?
Can't access using Chrome or Firefox either.
I suspect that the User Name and Password that I have has expired.
juangelb
Hi People,
I am having problems in using the new link.
1- CPU goes to 100 % using I.E, Firefox and Chrome.
2- This happens in 4 different computers 3 different internet connections, so I Think that the problem is not at my side
3- In all the cases the computers stays locked, unresponsible....
No way to use RB24 this way
Is someone else getting this scenario ?
Cheers - juan
On logging in I am advised that Radarbox i snot responding due to a long running script.  Pressing the stop script button causes it to hang with the following error
Problem signature:
  Problem Event Name:   AppHangB1
  Application Name:   iexplore.exe
  Application Version:   9.0.8112.16446
  Application Timestamp:   4fb57c8f
  Hang Signature:   d8dd
  Hang Type:   131072
  OS Version:   6.1.7601.2.1.0.768.3
  Locale ID:   2057
  Additional Hang Signature 1:   d8dd82640bdb35ee0f2704704f2f92fe
  Additional Hang Signature 2:   7f6c
  Additional Hang Signature 3:   7f6caed11ebb077ab926dca8f9a0d658
  Additional Hang Signature 4:   d8dd
  Additional Hang Signature 5:   d8dd82640bdb35ee0f2704704f2f92fe
  Additional Hang Signature 6:   7f6c
  Additional Hang Signature 7:   7f6caed11ebb077ab926dca8f9a0d658
juangelb
Yes Runway31,
Several problems here including what you pointed.
Lets wait ...
Cheers - juan
juangelb
Hi AN 3D Dev.
1- At his time https://www.radarbox24.com/VLypwHDPQN/ working fine
2- Even when opened it is remembering the settings (place of the map ... zoom), this never worked before.
Congratulations !
Cheers - juan
Today I have been working on the ASDI & Grid View sorting and this is probably what was causing the CPU spiking. There previous way I had the grid setup was causing way too much CPU usage. I think I solved this issue so if you clear cache and reload it should work again. ASDI is still unavailable in grid view however. Please test the grid view sorting and let me know any feedback.
#29
Quote from: Allocator on June 15, 2012, 01:42:32 PM
Allocator -- what was your username/email that you are using to log? Send me an email and I'll and I'll double-check that your account is working correctly - [email protected]
