Started by orkney, July 22, 2012, 07:26:17 PM
Northern Watch
Afternoon Alan
Not populating today was:
AE0740 / F15 / Tac Code.  One site has this as 00-3003 but as you know these codes are usually used by numerous aircraft.
Keith
Thanks for the tac code Keith.  Yes the cade changes each flight and what was identified as using it today will use another code its next flight.
The F15's have even been noted changing their code in flight and I even saw reference to 3 separate aircraft using the same code at the one time within the last couple of weeks.
They occasionally have been noted using Russian codes among others, naughty!!
Hi X,
N937FR is an ex Frontier A319 on a flight test out of Shannon on a post maintenance shake down flight prior delivery to Brussels Airlines
AC6B63, N9KH, Bell 407GX, c/n 54341, J R Kilpatrick Aviation
Xon
896181 A6-EEB A388 Emirates Airlines c/n 109 [Delivery XFW-DXB UAE7380]
flygfantast
Not populating:
47942D c/s RTG1016, 919 msgs
AAA714 c/s N786CT, Airbus A319-112 c/n 1786, CIT Leasing
Niklas
Cable: Ecoflex-10 (10m+1m)
Kenny
Quote from: flygfantast on November 06, 2012, 05:47:25 PM
Quote from: Runway 31 on November 06, 2012, 05:40:41 PM
Nothing on it Niklas, unfortunately
Could be HS-GBG, info from Skyliner:
Saab 340B, c/n 457, HS-GBG, Nok Mini Airlines, N-reg canx 31oct12, delivery 05-06nov12 BGR-KEF-TBS    ex N453XJ
Niklas
Hi Niklas,
Searching for N453XJ and not sure about the c/n 457.  Found on A.net as 453 while c/n 457 is N457XJ
ANRB 3km north of VTBD
Hi Niklas,
47942D, LN-RTG, Dassault Falcon 2000 c/n154, Rely AS
N453XJ c/n 453 cancelled to Thailand 31/10.  N457XJ c/n 457 still on FAA list
HS-BGB is c/n 453
X
I assume no longer stored and en route for a new identity, just gone OTT at 16000 climbing out of AUH.
* A6EA91                           N545AT  AT75  WFU Stored (ex Ex... 2012/11/09 23:29:21
X
X
760950 Pakistan unknown descending into area
X
X
A6EA91 N545AT to be XY-AJD for Air Kanbawza was stored in Eindhoven.  Skyliner shows it on delivery 09-11nov12 BLL-TZX-AAN-NAG-RGN, N-reg
760950 decodes to AP-BJP but nothing on it yet
Morning, the unknowns from Friday:
150779 (Russian Federation, flight id: RA67433, RA-67433 is hex 150769, so a decoding error)
261575 (no allocation, no flight id, whether a decoding error or a miscoded airframe)
3D4169 (Germany, flight id: DEXAF, D-EXAF E300 Extra E330LC Private 1313 sources/Mk1EBs: http://www.skrzydla.org/showphoto.php?photo_id=99980&cd=5398f61e583eee75659425f7b3c7e775  and http://www.airplane-pictures.net/photo/223417/d-exaf-private-extra-330lc/ )
3F8D3F (Germany MIL, flight id:  NOBLE01)
3FF1AD (Germany, no flight id, only two messages received)
42414B (UK, flight id: VPCDE, VP-CDE no details about the new one)
46A066 (flight id: QTR078, decoding error, several hex with this flight id in the list)
471EA2 (Hungary, no flight id, nothing more)
471F41 (flight id: WZZ9LG, decoding error of 471F49)
8961AA (UAE, no flight id, was A6-RJH LJ35 until 2009)
Have a nice weekend!
Northern Watch
Evening Alan
On the move today EBBR - BIKF was Ex-Brussels Airlines / B734 / OO-VES / 44D8B3 which has stored/WFU in the details.
This I take it is on its way to the USA to become A61B40 / N493AC / Aircastle.
Keith
