Started by orkney, July 22, 2012, 07:26:17 PM
I dont have anything on it at my end X
X
A friend also picked up unknown 504DF2 in Al Ain area (well out of my range), I wonder if the 76's are going through their seemingly annual change of reg's or it could one of the ER- An26's transitting from/to FJR over AAN.
X
X
Quote from: X on November 08, 2012, 05:33:55 PM
Pretty sure now that this is 60-0356 K35R miscoding as we know its in the area should be AE04E8.
   AE0CE8  ELITE38                                                     2012/11/08 11:04:00
   AE0CE8  ELITE38                                                     2012/11/08 14:22:41
And 8hrs later guess what
  AE04E8  ELITE62                  60-0356 K35R  US - Air Force       2012/11/08 22:11:22
Someone listening in to me?
X
AE0CE8 has been confirmed as 60-0356 miscoding at Mildenhall 20/21 Nov.
X
Kenny
Quote from: Runway 31 on November 25, 2012, 06:31:31 PM
No Kenny, they will be on the server from later tonight and show on network flights.  Unless you add them to your d/b yourself you will require to wait until the next Navdata release in around 10 days.
Umm  new Navdata in 10 days....  That's mean something.
ANRB 3km north of VTBD
It means that the new Navdata will be released in around 10 days, simple as that.
X
There was some discussion on the mode-s forum last night and it is considered that AE0CE8 is indeed a one box miscode of 60-0356 and as such have added it to the d/b.
However nothing confirmed 100% at this time and the mode-s discussion gives the following info which somewhat contradicts your statement that AE0CE8 has been confirmed as 60-0356 miscoding at Mildenhall 20/21 Nov.  It may well have bben the case that it used the other box later in the day on 21st.
" AE04E8 was last reported in the USA on 21.11 but 60-0356 could easily have flown back to the Middle East in the last few days via northern or southern latitudes, thereby avoiding detection.
Where did you get your Mildenhall info from?
X
#1551
Paul got Mildenhall from Mode S Forum, but neither AE04E8 or AE0CE8 have been picked up since 16/11/12 and there have been several 'new' C135's just arrived so we assume it has been replaced and would be returning to US as is the US norm out here of swopping around six per month late in each month.
I understood it had been confirmed but from your email I assume it was not. I am still howevcer convinced that it is the same aircraft as there was never a cross over in the four months the two codes were noted and all other C135's out here are known and code correctly.
X
Hawkeye
Another rake of routes from yesterday, mostly easyJet again, and all verified – crosschecked this time :-)
EZY497F            EPKK      EGAA
EZY189A            BIKF       EGGW
EZY17X              EGPF      EGGW
EZY271Y            LFSB       EGPH
EZY943M           LEMG      EGPH
EZY711E            EGNT      LEBL
EZY678K            EGGW    EGPD
EZY778X            EGAA      EGSS
EZY829E            EGCC     EHAM
EZY157C            EGGD     EGPH
EZY337G            EGKK      EGPH
EZY235G            EGGW    EGAA
EZY890P            EGGP      EGAA
EZY62GH            EGPD      EGGW
EZY263W           EGSS      EGAA
EZY956U            EGSS      EGPF
EIN03C             EGAC     EGLL
EIN03X             EGLL      EGAC
TCX3217           DTNZ     EGPF
EXS897             EGCC     LHBP
CLX750             ELLX      KIAH
CLX838             ELLX      KATL
DAL107            EDDF     KJFK
Also three obviously incorrect:-
RCH425         KSUU/KRIV
EXS041A        EGAA/EGPH    Was over Lincs heading SE
EZY453P        EGGP/EGGW   Was abeam DCS heading SE
Syd
X
this should be B-3098 E135 on delivery via sandpit
* 780394                                                              2012/11/26 19:43:03
X
X
60-0356 populated as BKC3 due to the usual AirNav type glitch so needs you to manually change it at your endand B-3098 has a 4 missing in the c/n ie 145XXXXXX not 15XXXXX
Hi Syd,
Many thanks again
EZY453P is EGPF-EGGD
From what I can find EXS041A is a positioning flight ID
X
Its your end that needs the manual update.  Its the software on your computer that has the problem.
Added the 4
X
Non populators on network
5082B2  URCLM
4844B7  KZR1382
X
Nothing on wither of those yet X
