Started by orkney, July 22, 2012, 07:26:17 PM
Hawkeye
Another batch of routes.
I feel I shouldn't be loading you with so many really
with all the time you and the team already spend on aircraft data.
EZY33BT    EGPF/EGGD
EZY142V    EGGD/EGPF
EZY73AU    EDDT/EGPF
EZY630L    LFLL/EGPH
EZY630L    EDDM/EGPH
EZY378C    EDDM/EGPH
EZY174C    LFMN/EGNM
EZY452T    LFPG/EGAA
EZY957E    EGSS/EGPH
EZY19B      EGGW/EGPH
EZY419U    EGPH/EGGW
EZY754R    EHAM/EGPO
EZY921D    EGSS/EGAA
EZY184B    EGGD/EGNT
EZY38BT    EGPF/EGGD
EZY76C      EGGW/EGPF
EZY478E    EGAA/EGGD
EZY974H    EHAM/EGPH
GEC8170   EDDF/KATL
DLH428     EDDM/KCLT
DLH410     EDDM/KJFK
MPH1187   EHAM/KMIA
BAW1489  EFPF/EGLL
ABQ220     OPRN/EGCC
RYR6DC     EPKK/EGNM
AFR025R    LFPG/EGNT
RYR6GQ     EPBY/EIDW
EXS898     LHBP/EGCC
BAW835    EIDW/EGLL
EXS174C   LFMN/EGNM
DAL29       LFPG/KATL
RYR1FL      EGNX/EPKK
SHT8Q       EGLL/EGPH
WZZ2JC    EGGP/EPMO
RYR38P     EPGD/EIDW
Some incorrect ones:-
RCH81            KWRI/KPOB      Obviously wrong
EZY623Y         EGGP/LFMN      Should be EGGP/EGAA
BER242X        EDDR/ EDDM    Wrong. On box E of MAN, Hd W
TOM9289       EGGW/EINN     Wrong. Departed  EGSH but destination unknown.
FDX36            KIND/LFPG        Should be KIND/EGSS
EZY718B        EGGD/EGGW     Should be EGGP/EDDB
NJE9AD          KTEB/KSAV       Was EGLF/KSJC on 28th -  Netjets callsigns are allocated to the plane, – in this case CS-DKH, - not the route.
See:-  http://www.ciaviation.com/newpage25.html
Better if all NJE c/sns are removed from database?
Syd
Thanks Syd,
your help is very much appreciated.
Some queries
FR24,gives EZY142V as EGGD-EGPH
You give EZY174C LFMN/EGNM. According to the easyjet website their only route from Leeds is to Geneva
BAW1489 is EGPF-EGLL and uses SHT7P as its alternative callsign
I am happy to be proved wrong but I think RYR38P is a positioning flight as I cannot find it on the net.
Agree re business flight and advised Airnav to delete all thier callsigns from Routes d/b a few days ago.
Similar with RCH etc flights, these have stopped being added to d/b but still a couple of hundred in d/b and Airnav have been requested to delete them all
paul tricker
non-populator..
75829E  RPC3271  = RP-C3271  A320-214  5381  Cebu Pacific Air
just gone OTT the sandpit ABOVE the clouds : -(
Paul
Hi Paul,
Its in the d/b since departure so should have populated
Hawkeye
Evening Alan,
Regarding your queries.
EZY142V is indeed EGGD/EGPH. Had it correct on a list I sent previously!
SHT7P was showing on R/B as SHT1489  (not even BAW1489) which it has done before. Don't know the answer re cross ref in database for such cases. I hit 'F' (which lives next door to 'G' on keyboard) in departure airport code. No excuse. Doh.
RYR38P.  Don't think this one is a typo on my part as I'm pretty sure it was showing that c/s on screen. Research shows though it was RYR3BP.  Route correct as submitted.
EZY174C. Sorry Alan, can't explain this one even though I generally double check  'track lines' on other VR sites and expected arrivals details at airports.
Beginning to think 'advanced years' is getting the better of me. Perhaps I should retire from the scene gracefully :-)
Syd
BBJUK
Morning Alan.
UP-T3409 TU134B-3 arrived AUH overnight, hex is 683066.
Nice way to start the month.
Cheers BBJUK
Many thanks BBJUK, nice start indeed, send it over here please when you are finished with it
Hey Syd, no worries keep on sending them in.
I will put the shuttles in using both their original and alternative so as we get them whatever they use.
Many thanks and keep on sending them in, I get fat finger syndrome more than anyone!!
flygfantast
On screen just now again (seen November 5th) is 150779. Seems to be RA-67433, allocated 150769, miscoding on one of it's boxes.
RA-67433, Cessa 525 CitationJet 1, c/n 525-0484
Niklas
Cable: Ecoflex-10 (10m+1m)
Xon
48D84F 025 C295 (PLF033 delivery flight)
Blueboy
Hi Alan, picking up HEX A5F1FC with Flight ID of 50482 - Possibly PC-12 / U-28A  05-0482, which I think is inbound Prestwick
J.D
#1618
Hi JD
If thats the case its a miscode, A5F1FC decodes to N482WA although it appears to be the norm for them ansd quite apt given it is c/n 482
Many thanks
X
Looks like we have another little Fokker, should be EP-FQA
* 731A21                                                              2012/12/01 11:05:29
X
