Started by orkney, July 22, 2012, 07:26:17 PM
X
New visitor to sandpit
800709  VT-ZST CL60 Challenger CL604 5629 Zest Aviation
X
Morning!
Some to check and amend:
3E167E D-HZSG is in the db with operator Bundespolizei. The operator shall be Bundesministerium des Innern (BMI), as this one is one of the bright orange MEDEVAC helicopters operated by the BMI. D-HZSG is currently servicing as CHX4 here in Hannover.
Please check the following too:
3E1678 D-HZSA (in database with operator Luftrettung Bundesministerium Des Innern)*
3E1679 D-HZSB (in my db with Bundesministerium des Innern)
3E167A D-HZSC (in db with entry Luftrettung, but is operated by BMI)
3E167B D-HZSD (in db with entry Luftrettung, but is operated by BMI)
3E167C D-HZSE (in my db with Bundesministerium des Innern)
3E167D D-HZSF (in my db with Bundesministerium des Innern)
3E167E D-HZSG (detailed mentioned above)
3E167F D-HZSH (The 'D' in des is upper-case, but need to be lower-case)
3E1680 D-HZSI (in db with entry Bundespolizei, but is operated by BMI)
3E1681 D-HZSJ (in db with entry Bundespolizei, but is operated by BMI)
3E1682 D-HZSK (in db with entry Bundespolizei, but is operated by BMI)
3E1683 D-HZSL (in db with entry Bundespolizei, but is operated by BMI)
3E1684 D-HZSM (in db with entry Luftrettung Bundesministerium)
3E1685 D-HZSN (in db with entry Bundespolizei, but is operated by BMI)
3E1686 D-HZSO (in my db with Bundesministerium des Innern)
3E1687 D-HZSP (in my db with Bundesministerium des Innern)
checked all listed registrations. All Helicopters are the bright orange ones operated by the BMI.
* We should fix to one common entry:
All Bundesministerium des Innern shall either be Bundesministerium des Innern or, if we decide to give the additional information "Luftrettung" in-front of the operator itself, Luftrettung Bundesministerium des Innern.
The unknowns from yesterday are following...
Thanks Ingo,
All standardised to Bundesministerium des Innern
The unknowns from Friday:
3442D4 (Spain, no flight id, nothing more)
3C630C (Germany, no flight id, decodes to D-AHXL, nothing about an active airframe using this reg. So I presume a decoding error)
3D9818 (Germany, no flight id, decodes to D-GDVS, but on airframe it is mentioned that this could also be D-GDVK repeatingly sending false hex. )
3DAFA5 (Germany, flight id: DGMTP, nothing more found)
3FCA51 (Germany, no flight id, D-OOAZ BALL Colt Balloons Ltd Cold 90  Thomas Ruchay 4928 sources: http://www.airport-data.com/aircraft/photo/555670.html & http://www.ballonfahrer-online.de/bo_datenbank/datenbank_datenblatt.php?id=780)
3FEBD9 (Germany, flight id: DMUSP, no luck with the details)
3FF009 (Germany, flight id: DMYQR, D-MYQR ULAC P&M Quick-R 912S Private CN:? last Mk1EB April 2012 posted at flugzeugforum.de)
3FF0C2 (Germany, flight id: DMKPC, D-MKPC FK9 B & F Technik Vertriebs GmbH Speyer FK 9 ELA Flugschule Klaus Pöllmann CN:? source: http://www.ul-fliegen.eu/mitte3.html )
3FF187 (Germany, flight id: DMXSE, D-MXSE WT9 Aerospool WT-9 Dynamic Private CN:? source DULV / http://mail.dulv.de/fmi/xsl/LTA/browserecord.xsl?-lay=LTA-Web-Details&-recid=9172&-find=-find )
3FF1B4 (Germany, flight id: DMKUN, D-MKUN C42 Ikarus C-42 Private CN:? Mk1EB May 2009: http://www.abpic.co.uk/photo/1176455/ )
424295 (UK, flight id: ORB9401, ORB: Orenburg Airlines, nothing more)
484F10 (Netherlands, no flight id, could be a decoding error)
484FB5 (Netherlands, no flight id, nothing more)
4891A8 (Poland. flight id: ENT734T, SP-ENI B734 Boeing B737-43Q Enter Air cn 28489 / ln 2827 source: http://www.planespotters.net/Production_List/Boeing/737/28489,SP-ENI-Enter-Air.php confirming: http://www.airfleets.net/ficheapp/plane-b737-28489.htm )
4A0091 (Romania, flight id: FAT7RG, still no luck with this one)
780900 (China, flight id: TBA5256, already populated to Database)
780955 (China, no flight id, already populated to Database)
A2B922 (USA, no flight id, would match to N275AU, nothing about a new airframe using this reg. )
MIL List:
3E8BDD  TA69
3E991D  GAF960
3F9DCC  GAF019
3F9DCC  GAF019
That's all from yesterday. Have a nice Weekend!
BR Ingo
Quote from: Runway 31 on August 18, 2012, 08:06:55 AM
Thanks Ingo,
Did the same. Thanks!
Hi Ingo,
3442D4 unknown to me
3DAFA5 D-GMTP, unknown to me
3FEBD9 D-MUSP, unknown to me
3FF009 D-MYQR ULAC P&M Quick-R 912S c/n 8573
3FF1B4 D-MKUN C42 Ikarus C-42 c/n C42-0081
424295 VP-BEI, Boeing 737-86J, c/n 30881/1067, Orenair
484F10 unknown to me
484FB5 PH-KMF, SOCATA TB20 Trinidad GT
4A0091 as its flight ID is FAT7RG, I am going to hazard a guess it is 4B0091 HB-AFP Miscoding
Regards and have a good weekend
X
* 51526E  NAS502                                                      2012/08/18 15:23:03
This is EY-622 A320
HS-TXC  en route DXB on delivery, assume code is already in db
X
Hi X
Yes 885303 HS-TXC, Airbus A320-214, c/n 5258, Thai Smile already in d/b
I have EY-622 now as E7-SKB with Sky Bosnia/Iraqi Airways since around about May this year so I guess it still using its old hex.  It went to EX-32003 after being EY-622 and is now E7-SKB.
X
Maybe I didn't make it clear enough. E7-SKB has changed back to EY-622 and was seen as such on take off DXB on f/n NAS502.
X
My apologies X, as you can see from my answer that not how I picked you up.  I presume its back with East Air who have sub leased it to Nasair
Alan,
Just flown over :
Mode S : 780901
Flight ID : HBH3208 = Hebei Airlines
chewycanes
Evening Alan
402749 G-BMXC C152 (FROM AF)
Brian
Hi Ian
Picked it up as well, but was out with the dogs
780901 B-3208, Embraer 190-100AR, c/n 19000566, Hebei Airlines
Evening Brian,
