Started by orkney, July 22, 2012, 07:26:17 PM
X
#570
514042 was parked at SHJ today so should be 4L-ABI A300F GCS Cargo c/s as suspected.
Plus this unknown
* 898080                                                              2012/09/06 10:44:21
We believe this PNG is a Lynden Herc that has been seen at DWC lately
X
X
#571
3X-GGQ IL-18 seen FJR today in pristine condition might be 0467F1 picked up cruising at 22000 before descending into FJR.
Have you a code for EY-322 An26 also pristine at FJR looking operational is likely to be one of our three current unknown Tajiks. Have you anything on this? Might be 515194 as 515261/2 are relatively new to the area.
X
#572
X
N407LC ex Lynden is now P2-LAE c/n 5225 with Lynden Air Cargo PNG
0467F1 was previously 3X-GGB an A320 which is now on the French register.  Unknown to me what is using it now.
Have everything but the hex for EY-322
X
At long last the first time EP-IEG is picked up using its correct code instead of its ex Japanese hex!
* 7324A7                           EP-IEG  A320  Iran Air             2012/09/04 19:41:00
X
Yippee, wonder about the other box
Judwin45
Hi Alan
Noted on 'My Flights' at about 1715 1E1111 Sq7000 no other details.
Keith
5 miles south of EGDY
Hi Keith
Airframes have this miscode as G-VIIZ, CSA SportCruiser, c/n PFA 338-14672, Skyview Systems
Evening, the unknowns from today:
000017 (no allocation, no flight id, maybe a gain the miscoded mil airframe)
3C7D90 (Germany, flight id: OLT210, decoding error of 3C7D94)
3CCD49 (Germany, no flight id, nothing more)
3CD055 (Germany, no flight id, received two times 3 hours between, decodes to D-CGEV nothing more)
3D45F7 (Germany, no flight id, decodes to D-EYTB, nothing more)
3EDE2C (Germany, flight id:  DKZCE, D-KZCE Stemme S6 http://www.alfacharlie.com/de/flugzeug/eday/d-kzce/ and http://www.abpic.co.uk/search.php?q=D-KZCE&u=reg )
48D828 (Poland, flight id: PLF116, PLF: Polish Air Force. Maybe this one: http://www.flightradar24.com/data/airplanes/0219 )
ABD6C4 (USA, flight id: FDX003, decodes to N862FB, but in this case a decoding error of ABD6C6)
MIL List:
3EB2B8  GAF727
3F851D
3F8D02  GAF061
3FB1C2  PANTER1
Have a nice evening!
BR Ingo
Evening Ingo,
3CCD49 decodes to D-CFAV unknown to me
3CD055 D-CGEV unknown to me
3D45F7 D-EYTB, Piper PA-28-181 Archer III, c/n 2843680
48D828 0219 An28, c/n  AJG004-02, Poland Air Force
paul tricker
A couple of non populators today...
A4DA03  DASSAULT  this is N411YF Falcon2000  c/n 161  Sand Hill Management
A34A85  N31098, only N31098 I can find was a Pa34-220T Seneca exported to Spain in 2006.
It is not current on the FAA, so either a bogus code or the EC- not recoded?
Paul
#580
Thanks Paul
N411YF was only registered yesterday
Nothing on N31098, the PA34 is now EC-JPO and was in at Prestwick today using its old hex
GreekSpy2001
German C-160 51+02 reported into BHX.  Seen climbing out over London at 11:40
3F545B  GAF012                                                      2012/09/07 09:49:54
Graham
Thanks Graham, tactical code
X
This IL76 is now EY-680 still miscoding
   68305B                           EK76111 IL76  RUS Aviation (Mis... 2012/09/06 02:51:15
   68305B                           EK76111 IL76  RUS Aviation (Mis... 2012/09/06 23:27:53
x
