Started by orkney, July 22, 2012, 07:26:17 PM
0 Members and 12 Guests are viewing this topic.
paul tricker
Quote from: Runway 31 on September 18, 2012, 07:47:16 PM
Thanks Paul,
Not aware ofthe operator either.
c/n 3840 now EC-LRL, possibly it you noted but without the flight ID, could be anything
N128ES was in the flight id column.
Paul
Sorry Paul, didnt see it he first time. Possibly the Spaniard but no way of knowing without an eyeball
mikek
3B9BB8, Falcon 20 Gardian, 65, French Navy, c/n 465.
Mike
Alan,
Just come on 'My Flights' :
Mode S : 00E4C9
Flight ID : RANGR85
Any Ideas ?
Hi Ian,
Going by the call sign Ian I would suggest it is a USN aircraft miscoding.  The hex doesnt decode to anything.
X
504E00 has just arrived somewhere but viz bad so no type
X
jim_stockwell
Good afternooon Alan
Not populating is 48B68C with a flight i/d of SP-NWM. I cannot find anything out about it on either the Gatwick or Airframes web pages to help you
Jim
Alan,
Two RAF Eurofighter Typhoons are currently flying around. (At least I assume they are both Typhoons ) One is showing in 'My Flights' as ZK304 c/n BS055, the other is not showing on the RB. Have you any ideas. Is the other one showing on your box by any chance ?
X
#685
We believe EY-609 IL76 has been recoded 515261 as it  stopped pinging old miscode hex 60005F on 3/8/12 and new hex appeared 9/8/12 and has been seen regularly at SHJ since and times for 515261 fit our sightings. We therefore guess that EY-610 is 515262 which is irregular to say the least. They also fit in the sequence of all the new EY- IL76 machines that code correctly.
X
Hawkeye
A couple in MyFlights earler not showing regs, but the callsigns apparently tie them up.
A72B3E showing callsign N561GG which was G-WINT until recently.
48B68C showing callsign SP-NWM
Syd
Jim,
48B68C SP-NWM first noted 16th, no tie ups available as yet.  Logged at Glasgow 17th, Middlesborough 17th and Ondara 16th
Hi Syd,
Orkney added the PC12 earlier and see reply above re SP-NWM
Ian,
I only picked up the same one as yourself, ZK304, flight ID WOLF0031.  Picked it up yesterday as well.
