Database Update Requests
Started by orkney, July 22, 2012, 07:26:17 PM
Chris11
00B545 HAWK   Hawk Mk-120 Lead In Fighter Trainer (LIFT)   South African Air Force Tail no 270
Chris11
00B273 ZS-TCC - Owner L & P Partnership
Many thanks Chris.
Hawk c/n SA21
superspotter
Hello again from Lagos;
Two bits of info: Hexcode 064121 is 5N-BOQ Ce560 operated by Bristows Nigeria. and D-CIRJ Do328 with hexcode 3CD6E3, the Airnav Db has this as WFU however it has just arrived with callsign BML 328 and my Db has this as Abuja based and operated by Prime Air Services. regards clive.
My equipment: Airnav mobile antenna stuck outside of the highest hotel window available!
View my pictures at  http://www.flickr.com/photos/superspotter
X
Quote from: Runway 31 on October 27, 2012, 03:47:40 PM
Hi X,
42491A decodes to VQ-BZB which became TC-CLH CL605 unless it has been re-allocated
Hi Alan
On checking what landed at that time with someone on the ground I believe 42491A was actually 42493A VQ-BDP Nordstar B738 which I have heights either side of the time I saw it, so probably a crossed code as nothing else landed that fitted the bill and no one else picked up 42491A.
X
Chris11
Do you have the cn of the other Hawks?
Quote from: Runway 31 on October 28, 2012, 10:20:29 AM
Many thanks Chris.
Hawk c/n SA21
Thanks again Clive,  looks like we are both using the same d/b.  D-CIRJ was previously WFU stored ex Cirrus but is now operated as you state.
Chris,
Looks like the are in sequence order from 250 SA01 upwards, 251 SA02 etc
superspotter
Another from Lagos: Hexcode 064000 is 5N-MPB Be350 Mobil Oil Nigeria, regards clive.
superspotter
A miscode going on here with Ethiopian Airlines and Asky airlines, not for the first time I have noticed. Just had hexcode 04002B appear as ET-ANI which is a DHC-8 but landing was a 737. I suspect it is ET-ANH as the other two, ANG and AOK regularly appear. regards clive.
Hi Clive,
04002B is def ET-ANI DH8D
I have just checked the d/b and dont have a hex of ET-ANH, checked GAS, Airframes AvDb and they dont have its hex either.  Going by the registration sequence I would have expected ET-ANH to be 04002A but nothing on that hex
I am certain that I have seen something previously on the mode-s forum but the search facility is crap and dont get anything.  Will keep trying but may need to mark the hex as being used by various aircraft.
superspotter
OK. I have noticed this in the past with Ethiopian/Asky but didnt note which aircraft it was at the time. But I flagged this one up to watch a couple of days ago because I need ANI so when it appeared today I made sure I saw it on approach and it was definitely a 737 in full Asky colours. ANG appeared a few minutes later enroute ACC-ADD and I have seen AOK a few days ago. regards clive.
Will mark as being used by more than one aircraft
Thanks Clive
