Cannot save changed Colours
Started by dl1812, July 26, 2012, 11:52:21 AM
dl1812
Quote from: bearcat on July 27, 2012, 01:15:14 PM
Right click  on ANRB icon and Run as Administrator. Start in Demo Mode and enter your details then restart and should then work. You need your box s/n
Just for the record mine runs fine on d drive
Thanks Bearcat, but no joy.
- and mine ran with no problems on my d: drive, I had to move it it to my c: drive because of other issues.
bearcat
Sorry to hear that. Can't remember but do you have to enter your home station location, email etc when you log in in demo mode.You may have to try this 2 - 3 times, I remember I had a few problems. If you use 3D after a few installations Airnav may have to reset your profile. Otherwise I'm running out of ideas sorry
dl1812
Thanks for your advice Bearcat.
Done all that :o(
At least you'll be pleased to hear that you're part of my first Post that's run to two pages !!
Dave
I dont know how many instances you have had of Radarbox, 2 is usually the maximum.  If  you have had that contact support and get them to re-set. you will need your PGANRB details.  Even if its not that its still worthwhile contacting them anyway for their assistance
Contact support at [email protected]
bearcat
A couple of thoughts. Did you restart your laptop between uninstalling and re-installing Rbox as this helps to get rid of the old settings, I've had this scenario before
Also you say it is a works laptop, do you have full administrator rights to install programs?
dl1812
Many thanks to those that tried to help me with this problem, and my apologies for my late reply.
My IT Manager is coming to see me on Monday, and to be honest I feel that he'll see the best solution as removing ANRB from my Works Laptop.
A fair shout, to be fair, but we shall see....I'm actually his Line Manager :o)
If the problem's solved  and the solution proves to be worthwhile putting on here, of course I'll do that.
Dave
dl1812
I have now spent a whole day, on and off, with our IT Manager, and sad to say, there are too many problems running the Radar Box wiithin a Works Network environment, so I've agreed to remove it.
This actually may prove to be the end of my Radar Box altogether, as I've little spare time at Home; we shall see.
Many Thanks to all who tried to help; your kind efforts were very much appreciated.
Best Regards
Dave
Sorry to hear that, Dave
It might be worth contacting AirNav Support directly - they do claim to offer corporate solutions.
dl1812
Hi Rod,
We're shortly updating our Company AUP, which specifically bans non-business approved software.
As I'll be co-signing the Document, then now's probably a good time to uninstall it. !
Shame really, but it is a Work pc, after all :o)
I can still use FlightRadar 24, so I probably won't miss too much.
Thanks again to all who offered their assistance; that's is what makes this Forum as good as it is.
Dave
You could still run Radarbox on your home PC, and then access it using Teamviewer.
No software installation needed on the work PC, just install teamviewer on your home PC, setup a teamviewer account, and access your home PC at work from https://login.teamviewer.com/
By the way, there is a free Teamviewer App for Android Smartphones available too.
And for iPad as well.  Once you've got Radarbox running at home, it's easy to access it from anywhere with Teamviewer.
dl1812
Thanks Tarbat, good idea. I'll have a play tonight when I get Home.
....or should I say IF I get Home....there's been some kinde of Bike ride going on around here today, and a Guy with Paul Weller sideburns has won a Gold Medal for riding a Bike.
All I ever got for riding a bike was cramp and a sore undercarriage :o(
Dave
