Logos
Started by RodBearden, July 29, 2012, 08:20:36 PM
0 Members and 8 Guests are viewing this topic.
Morning Rod,
Some more additions :
MAF - Aerolineas MAS (Dominican Republic)      http://www.aerolineasmas.com/
(We have this as the ICAO for the Mexican AF which has obviously been incorrect, so not sure what there ICAO code is if any. The FAA site doesn't appear to give a code).
SZA - Shenzhen Astro General Aviation/Astroair (China)            http://www.astroair.net/en/about/about.aspx?id=39
Now for some further confusion. There appears to be an ICAO code of 'TBM' for Taban Air of Iran but also an ICAO code of 'TBN' for Taban Airlines (spot the difference) also of Iran.
TBM - Taban Air                   http://en.wikipedia.org/wiki/Taban_Air
(I would replace our current 'TBM' logo which shows the name as Taban Airlines with this one).
I have searched for a tie-up for ICAO code 'TBN' and any I have found show the same logo as that for 'TBM' so not sure what is going on !
TEZ - Tez Jet Air Company (Kyrgyzstan)                   http://www.ch-aviation.ch/portal/airline/TZJ
TPD - Tropical Aero Services (Dominican Republic)    http://tas.com.do/
TTY - Thai Tours and Trans Airways (Thailand)          http://www.3t-air.com/
VSM - Vietstar Airline Corp. (Vietnam)                      http://vietstarairlines.vn/eng/Default.aspx
WZA - The Weather Co. (Australia)                           http://www.weatherzone.com.au/
Thanks Rod.
Now going for a lie-down after that lot !
Hi Ian - thanks for that ;-)
MAF - Aerolineas MAS - I know that the Mexican AF has used this code in the past, so replacing it with this logo is entirely optional.
TBM/TBN - Taban Air - I've hunted around, and most reputable sources say that Taban Air/Taban Airline (their website uses both names) is TBM. The exception is CH-Aviation which does give TBN, but all agree on the IATA code of HH. No website (apart from the FAA ICAO codes site) lists Iran as having two airlines called Taban, so why not have them both?
WZA - The Weather Co.trading as weatherzone
Thanks Rod.
Probably unlikely to see Taban Air anyway.
#2134
Speaking of the Mexican Air Force, a Mexican Navy plane is coming over as I type this:
ANX - Mexican Navy / Armada de Mexico
BlinkNFG
Afternoon Rod,
Can you cancel the logo for ICAO code 'BBZ' relating to Blue Bird Aviation which we currently have in the logo folder.
Having done some checking, there are, in fact, two companies with similar names and different ICAO codes and logos :
BBY - Blue Bird Aviation (Yemen)                http://www.bbaye.com/
BBZ - Bluebird Aviation Ltd (Kenya)            http://www.bluebirdaviation.com/
Similarly with the logo we have against ICAO code 'EAV' for Elit'Avia as again there are two companies with similar names but different ICAO codes :
EAU - Elitavia (Malta) Ltd                               http://www.flickr.com/photos/23071306@N08/11780819934
(This is all I can find for this company. They don't appear to have a logo !)
EAV - Elit'Avia d.o.o. (Slovenia)                     http://www.elitavia.com/
(Different from our current 'EAV' logo in the folder)
Hi Ian - thanks for those:
EAU - Elitavia (Malta) Ltd - can't find anything much about them - one site says that it's a hub for EAV, but the EAV website makes no mention of Malta, so I'm discounting that. So I've added a Maltese flag to the old EAV logo - why waste it!
EAV - Elit'Avia (Slovenia)
BlinkNFG
A couple of Wells Fargo Bank aircraft without logos (N231CE and N304CC).
Also without logos:
CGBBB - Chartright Air - http://www.chartright.com/ (logo already exists for HRT flight code so I'll copy that)
N502QS - Netjets Aviation (again flight code logo exists)
Jon
Jon
Hi Jon
I can't find anything for an owner/operator of N231CE.
N304CC is operated by Advanced Air Management. We already have their updated logo but here's a zip with all their current aircraft.
Please do copy existing logos for yourself where we have them - especially for large fleets like Chartright (and NetJets!).
BlinkNFG
Bizjet:
P4-MAK - B737 of Samrussitera
Thanks Rod. That's absolutely perfect.
I noticed that site that's makes reference to 'EAU' and 'EAV' being linked but like you it made no sense as the main 'EAV' website didn't even mention it !
CYYZGUY
Mode-S A034CB
Flight ID N112MY  (MP Air)
No Logo
regards,
Jason
40" LED Monitor
40" LED Monitor
#2144
Hi Jason - MP Air is part of Mylan Pharmaceuticals. We already have the logo for sister plane N902MP - here are logos for them both.
