Logos
Started by RodBearden, July 29, 2012, 08:20:36 PM
Hi Ian
Here's JFE - Jamaica Far East
AirAsia Japan's offiicial code is WAJ and we already have that.
Whoops, stubby fingers !
vonsmalhausen
we had a Chilian B767, reg 985, at Brussels the last 2 days
it just departed direction Atlantic, so probably some of you in the UK should be able to pick it up.
we have a logo for the Chile AF, but it is just the roundel, so i made a replacement/alternative
Here's a white-background version of the new AMC Air Malta logo.
Seen on the network at Brazzaville:
TSG - Trans Air Congo
DCT - Directflight
I see from their Shetland Islands scheduled Islander timetable that they use flight numbers starting DFL, but that code apparently belongs to Scandinavian Medicopter AB. If the aircraft use that code users may want to copy/rename this logo.
Some detective work (so this might well be wrong):
N1MG - C25B registered to Hagedorn Aviation. James Hagedorn is the president and chief operating officer of Scotts Miracle-Gro - hence the registration suffix. So I've done their logo.
Two more bizjets:
L30LB and L50LB - F900s of Hangar Acquisition Corp, who own Queen City Jet Charters on whose website they feature.
Thai Smile uses the same ICAO code, THA, as Thai Airways International, so at the moment we can't tell one from the other from the code.
Here's the Thai Smile logo for users who more frequently get Smile flights than regular THA flights. It will have to go down as an alternative for now.
vonsmalhausen
just had F-HDMF, newest A320 operated by Air Corsica ( ex Air Berlin D-ABFL ) on my flights.
looking for a picture of her, i noticed that they had a rebrand of they're logo
ICAO code is CCM, aldo most/almost all of they're flights i capture use CC as code ( where the IATA code should be XK acording to Wikipedia )
#265
Thanks, Vonsmalhausen, but remember that CC.bmp isn't useful, as CC will be treated as an IATA code by RadarBox, and will show the corresponding ICAO code's logo as defined by your Airlines table in Navdata.
To get a CC i/d to show the CCM logo, you'll need to add or amend the CCM entry in the Airlines table.
Extract from my Airlines table below (the little bars show a duplicate entry, but RadarBox doesn't seem to mind.)
vonsmalhausen
yes indeed, i already did add CC as a Air Corsica entry in the DB
really hope this airline table will get updated one day ; now everythime there is a new DB, i have to recompile a updated file with the, excellent, Dbase edeting tool
vonsmalhausen
just had 8Q-MAF, Twin Otter operated by 'Maldivian Air Taxi' on the network, using reg as ID.
according to Wikipedia they would have MAT as ICAO code, but we already have MAT in the DB allocated to 'Main Aviation Corp.', looked it up in the JP Airlines, and there is no ICAO for the Maldivian in there, MAT being allocated to the Main Aviation Corp.
as we dont have a MAT logo in oure folder, i made one for Main av. corp. aswell
also made a ZIP with all the regs i could find for both companys
vonsmalhausen
another one, N926AD, Piper Malibu of Highfield Aviation
vonsmalhausen
just had a Augsburg flight, ICAO code AUB, the logo we have for that seems to be outdated, did a replacement/alternative
