Logos
Started by RodBearden, July 29, 2012, 08:20:36 PM
vonsmalhausen
just had D-AKBH, Challenger 604 of JetAir Flugg, on my flights.
using reg as id, no logo showing, so i started looking ; found out JetAir Flugg is part of Imperial Jet, witch we have under the JTI code in the logo folder, they are building a new website showing a different logo as what is on the logo we have and on the old version of they're website, so i suppose they are in the proces of rebranding
this is what probably should be they're new logo
I thought we had a Walmart logo, but I can't find it, so here it is for:
CL60 N601HW, GLEX N170SW, and GLF6 N762MS
They also have 17 Learjets.
vonsmalhausen
hy Rod,
while searching for other regs of the Walmart fleet, i found out they actualy have a ICAO code ; CGG
checked for it in the logo folder, we don't have it
Well spotted, vonsmalhausen.
For completeness, here it is:
CGG - Walmart Aviation - just a copy of the standard logo
N600CK - GLF4 of Calvin Klein - I think it's their only aircraft.
Morning Rod,
Manx2 would appear to have changed their name to Citywing with an ICAO code of BPS for which I do not appear to have a logo. Details :
http://www.citywing.com/cgi-bin/airkiosk/I7/181002i?NM=2&LANG=EN
#396
Thanks for that, Ian - my local airline and I hadn't noticed. The FAA and Airframes both have BPS as belonging to Budapest Aircraft Services, who operate as BAS Airlines. We haven't got that, either so here they both are.
EDIT: In light of ACW's info, in reply #402, I've renamed the logos, with the Citywing logo as an option.
Citywing (a trading name of Citywing Aviation Services Limited) is an Isle of Man based company which sells seats on scheduled air flights. Its business model is referred to by some as a virtual airline
In December 2012 Citywing acquired certain assets from Manx2 and commenced operations on 2 January 2013. It sells flights and services from several airports in the UK with bases in Belfast City, Blackpool, Cardiff and Isle of Man. Citywing does not operate the flights itself and the routes are flown by EU registered airlines Van Air Europe and Links Air.
In November 2012 a management buyout of Manx2 was announced led by Managing Director David Buck.  From 1 January 2013 the assets of Manx2 were acquired by the new company 'Citywing' and seats went on sale on the new company website on 1 January. The first "Citywing" flight took place on 2 January 2013
ACW367
Rod,
According to this site ICAO code BPS is Manx2 :
http://www.europelowcost.co.uk/airlines/manx2.aspx
And this site is for Budapest Aircraft Services/Manx2 in Hungary with ICAO code BPS:
http://www.prokerala.com/travel/airlines/budapest-aircraft-services-manx2.html
You learn something new everyday !
#400
Ian - it's all a little confusing - adding to the mix, the official IATA site has NM as not allocated at all!
ACW's is no better! Here's PSF which I've done with the Plymouth School of flying as the graphic, but with Aviation South West wording.
It seems that Plymouth School of flying doesn't trade as such - possibly due to the fact that Plymouth no longer has an airport. Aviation South West claims PSF as its parent and is based at Exeter, but at least one website has PSF as having moved to Newquay and renamed itself as Flynqy, but I can't find any reference to that on Flynqy's website.
Again I've done alternatives
ACW367
While the BPS code will be used by the Budapest Aircraft Services airframes used on Citywing flights in the UK.  It will also be used by their charter Brasilia and Bell aircraft operated in Hungary.
Citywing only has an IATA code NM.  For ICAO the donating airline code is used.  The 'Citywing' flight from Anglesey to Cardiff is currently operated by Links Air jetstream and this flight used the LNQ code of that donating airlines.  The old use of Van Air Dorniers for Manx2 used the VAA code.
In short BPS should be http://www.baseairlines.hu/en/our-fleet.html
Otherwise the Hungarian spotters will have the wrong logo for charters out of Hungary.
Many thanks, ACW.
Original post duly amended.
Thanks for the info ACW. That helps clarify the situation !
vonsmalhausen
had PH-JAX in my flights, a King Air owned by Verwelius, a big Dutch constructor
also heavely involved in the footbalclub of Ajax, hence the red collor of the King Air and the number 14 on the tail, referring to the number on the shirt of Johan Cruyf in his Ajax period.
he also owns PH-AJX ( whonder to what club this reg referes :-) ) a Falcon 7X, he got in replacement of PH-LSV, a Falcon 50EX ( i don't know if that one still fly's under that reg )
