Network down
Started by daniales, August 24, 2012, 10:36:12 PM
AirNav 3D Development
Quote from: daniales on August 25, 2012, 12:48:52 PM
Friends,
I cleared out history, cahes and cookies. I retried without success. Chrome and IE9 spent a lot of seconds waiting to connect but instead of it, continuing to show the message Erro 118 (net::ERR_CONNECTION_TIMED_OUT): O tempo limite da operação foi atingido.
A few days ago we moved to the beta site to a server located in Europe rather than in the USA where it was located before. There may be a DNS issue that is causing your connection to try to connect to the old server. Can you try these URLs and see if you get the same ERR_CONNECTION_TIMEOUT error?
https://europe1.radarbox24.com/VLypwHDPQN/
https://us1.radarbox24.com/VLypwHDPQN/
Note, the site will be hit-and-miss for the next  few days while I work on some major back-end changes so it may look broken at times.
Also, if you have problems, try viewing your browser "console"
(Chrome--Tools->Developer Tools, Firefox--Control+Shift+J, IE -- F12 and then "Console" tab)
I have a lot of debug info going to the console and if there are errors, there should be error messages visible (usually in red font). Please let me know of any errors you encounter as this helps in debugging.
daniales
Now, the US link is working for me.
Dani Glikmanas
Sao Paulo - Brazil
#18
Dev,
On trying both the above links in IE9 I get access OK but he page is still the same cluttered mess that does nothing as per the picture provided on page 1.   Everything is working OK on Chrome except that there is a red line through https. and  there is a red cross though the padlock.
Quote from: Runway 31 on August 26, 2012, 10:03:38 AM
Dev,
It seems that your IE is not loading the JavaScript correctly. Can you verify that you have fully deleted your IE browser cache?
IE -- Settings icon (upper right-hand corner) -> Internet Options -> "Browser History"-> "Delete" button
Then make sure "Temporary Internet Files" and "Cookies" checkboxes are selected and click "Delete". You may have an older cached JavaScript file that is causing it not to load correctly. Please let me know if that doesn't fix the IE problem.
Did as you advised and still the same when clicking on both links.  BTW it doesnt like the Security Certificate and get the following message when i click the links - The security certificate presented by this website was issued for a different website's address
If you use either of the two links above (us1.radarbox24.com or europe1.radarbox24.com) you will get the certificate error. Both server will eventually alias to "www.radarbox24.com" which is what the certificate is valid for. If you use www.radarbox24.com you will not get the certificate error.
Sorry, I forgot to mention you will need that random string on the end to access the beta:
https://www.radarbox24.com/VLypwHDPQN/
The correct scrren comes up for a fraction of a second then gets over written by the junk
Quote from: Runway 31 on August 26, 2012, 05:40:05 PM
Alan,
Would you try to hit F12 in your IE while the junk is visible (to open the developer tools). Then click on the "Console" tab in the developer tools window. Once the console is visible, refresh the Radarbox24 webpage. If you see any error messages in the console, could you please send those to me?
#26
I got it working in IE9 by doing a hard refresh - CTRL-F5  Although I do briefly see an "Invalid Token" message, but that clears and then works okay.
orkney
Dev,
Did what you advised and the console read out showed me the problem.  The first line showed that for some reason I had the Radarbox24 screen on compatability mode.  I have clicked the compatability mode again and it is now displaying correctly with everything back to the way it should be.
Quote from: Runway 31 on August 27, 2012, 08:18:03 AM
Dev,
Alan -- That's great news its working again. Thank you for noting that it was the "compatibility mode" that was causing this problem. I will try to add a software check to see if this is on and display a warning message for other users.
