Author Topic: No flags, Deja vu!!  (Read 9242 times)
superspotter
Re: No flags, Deja vu!!
« Reply #15 on: September 07, 2012, 08:36:53 PM »
Well as I mentioned earlier in another post I did originally install off the disc which loaded as airnav 2009 then upgraded to v.4.03. In the 2009 file on the machine there is a data folder but there is only one thing in it and that is MyLog.db3-journal. Anyway, when I am home I will delete everything and reload 4.03 only from this site to C:/Airnav as you suggested and take it from there? kind regards clive.
« Last Edit: September 07, 2012, 08:40:13 PM by superspotter »
« Reply #16 on: September 08, 2012, 07:02:10 AM »
OK Clive, maybe speak then
superspotter
« Reply #17 on: September 18, 2012, 11:14:32 AM »
Hope you are around this morning Alan!!
I am back home for one day and have just reistalled Airnav from the original disc which is v.2.01. I have completelky forgotten how to find version 4.03 in order to upgrade it before I go any further? kin regards clive.
« Reply #18 on: September 18, 2012, 11:22:44 AM »
I would de-install 2.1 completely then search for orphan files which will be left.
Here it is http://www.airnavsystems.com/download/anrb/403/ANRB403Setup.exe
Dont install to the default program files location, install to C:\Airnav or similar.  This will avoid windows vitrual store problems.
Also if its a 64bit version of windows you will need the 64bit drivers http://www.airnavsystems.com/download/ANRB/drivers/ANRB64bitDrivers.zip
Any queries, you know where I am.
superspotter
« Reply #19 on: September 18, 2012, 11:24:51 AM »
OK, being computer illiterate, I have no idea what you mean by orphan fles! However, I will press on and delete v.2 and download the 2 files you have linked to. I will be back....
superspotter
« Reply #20 on: September 18, 2012, 11:27:03 AM »
Back rather sooner than I anticipated! the link you ahve sent for the v4.03 is giving me the following message: The file or page you are looking for might have been removed,
 had its name changed, or is temporarily unavailable.
    • Rod's RadarBox Downloads
« Reply #21 on: September 18, 2012, 11:43:32 AM »
Clive
A funny character got into the end of that link - try this:
« Reply #22 on: September 18, 2012, 11:44:30 AM »
Clive,
Works OK for me http://www.airnavsystems.com/download/anrb/403/ANRB403Setup.exe  375Mb by the way so will take some time to download.  The problem may be the 2 symbols afterSetup.exe, delete these as its left by me pressing the space bar
By orphan files, I mean that there will probably still be an Airnav folder left on your computer after deletion.  Find it and manually delete its contents if you can as it may cause problems later.
superspotter
« Reply #23 on: September 18, 2012, 12:04:57 PM »
OK cheers Alan, whilst I was awaiting your reply, I managed to find another link and have now doen tha, ext step the 64 bit drivers and then the navdata. Will then connect the box and make sure everything is OK then attempt the flag update from Rod beardens page.
superspotter
« Reply #24 on: September 18, 2012, 12:09:12 PM »
Ah. Before I cock it up again! I have the 64 bit driver files already on my computer. When I click on it, it is asking me where I want to extract the files to? Bearing in mind the airnav is now in C:/Airnav, where exactly should I drop the 64bit file? The default path it shows when I go to extract is C:/users/clive/documents/ANRB64bitdrivers??
superspotter
« Reply #25 on: September 18, 2012, 12:17:52 PM »
Well I have just connected the box up and everything appears to be working great wothout touching the 64bit drivers. I have flags too!
« Reply #26 on: September 18, 2012, 12:19:55 PM »
Fingers crossed Clive.
superspotter
« Reply #27 on: September 18, 2012, 12:23:35 PM »
You dont fill me with optimism Alan!! :)
« Reply #28 on: September 18, 2012, 12:55:22 PM »
Ever the optimist Clive!!
