Box unworkable
Started by Sylwek, October 09, 2012, 07:22:24 PM
Hi John, I was going to suggest similar and take bank statement or proof of how you paid for it in the first place.  HTH.     CGJon
Sylwek
Cześć Rich,
Thanks for info. I have done almost everything with soft (including tasks from your list, I guess). The most important test of RB was to install "brand new" last version of soft in a computer where RB soft has never been installed. Still not working. So I decided to send the Box for repair.
pozdro,
Sylwek
FACTflights
Got my box back about an hour ago, South African Revenue Services released it after documentation was provided.
Will give a report later.
Thank you to support and Waters & Stanton.
John
ZS1AGH
John
ZS1AGH
No HF antennae at the moment.
Wel done, John - hope it works!
EDIT - looks to be working - I'm seeing returns from Cape Town again :-)
Hi John,
Good news indeed!
FACTflights
Seems to be working well so far, but does not remember the polar diagram.  It builds a new polar diagram, but when anything is changed, it starts afresh with a new polar diagram.
The data files D012 only has zeros in it.
Maybe I should reinstall 4.03
John
ZS1AGH
John
ZS1AGH
John,
Try going into Windows - Record Desktop before switching off.
FACTflights
Thanks Ian,
Will try that.
John
John
ZS1AGH
fossie1
Hi, my box has stopped receiving also. How much do they charge for repair as my box is 3 years old?
Stephen
My position is 16 miles north of EGAA Belfast international Airport (Aldergrove)
Give Walters and Stanton a call Tel +44(0)1702 206835
fossie1
Quote from: fossie1 on November 04, 2012, 12:52:09 PM
Hi Stephen,
Depends what they find wrong, if it's the normal problem with earlier Boxes (not wrong psu or similar user fault), they may do it for free, as this was a built-in defect (which AN will deny, no doubt, but so many going u/s tells its own story - AN and W&S have been absolutely superb in putting this correct however - so fair play to them!).
Sylwek
Hi CoastGuardJon,
Could you specify what the normal problems (statistically the most common) with earlier Boxes are? My Box is about 3 years old, too.
Sylvester
I belive it was the SAW filter on a specific series of box numbers on very early boxes
Hi Sylvester,
I don't know about "statistically" more like "statically" blowing the SAW filter, which as far as I'm aware affected all the earlier Boxes, my serial no. is 101XX, 03/12/2009 Engineers Comments on mine "front end SAW filter replaced tested all working ok", and 11/01/2010 Engineers Comments "board replaced usb replaced tested ok" and been erfect ever since, just some antenna problems.   HTH
